0 Members and 264 Guests are viewing this topic.
Hoppy
Quote from: apecore on November 21, 2016, 03:52:17 AM
Nick,
It seems to me that your signal is not being affected by HF/HV interferences.
Wouls this ends the discussion as Hoppy stated that the effect is created by additional gate pollution?
Kacher does do its work as it should.
Unfortenatly Nick....no Input/Output power indication.
I am very excited what Hoppy's comments will be ;)
I commented in an earlier post to Nick, that his Mazilli is unlikely to suffer badly from gate signal distortion caused by HV. I say this because I used a Mazilli in my early experiments with the Grenade / Kacher setup and I had clean gate waveforms compared to when running with a TL494 PWM push-pull oscillator with mosfet chip drivers.
apecore
Quote from: Hoppy on November 21, 2016, 02:26:11 PM
If that is true that means that the effect is powered by the kacher .... in Nick case
The assumption that the effect comes from the pushpull aint not right.
NickZ
    That may possibly be the case concerning my fets, but, I'll check further into it, as to them not being affected by the HV, HF, interactions.  Even with the ground lines disconnected from the devices, my gates, and drains show no peaks, just lower output.
   However, there are several other guys that have used the TL 494 to fet driver circuits, and have shown both the effect, as well as self running.  So, I hope we can move on now.
   By the way, not only was my Kacher on, during the scope shots, but it was producing the amplification "effect", as well.
Which can also be shown that in a video, if needed.
   My main concern for now is a proper working feed back path. Any help with that would be appreciated.
Hoppy
Quote from: apecore on November 21, 2016, 02:42:48 PM
Its not as clear cut as that because in both setups, although understandably, the Kacher induced current will affect the resonant condition under optimum tuning, which is why Nick and I have been able to get some 'effect' with the Mazilli, it is more pronounced with the push-pull, which is being affected by the HV as described by Bat1Robin2. At least this was the case with my experiments.
verpies
Quote from: NickZ on November 21, 2016, 02:18:19 PM
Are you saying, now, that the process of NMR emits no radiation?
Correct.
The McFreey process emits fast electrons but they do not qualify as pollution.  Radiation - yes, but that does not linger and can be stopped with plain aluminum foil.
