0 Members and 76 Guests are viewing this topic.
stivep
Quote from: verpies on November 22, 2016, 10:23:00 AM
The advantage of McFreey's  MO over Tk, Ruslan, Akula's is that the former is based on proven phenomena such as:
1) spin axis polarization by magnetic field,
2) directional polarization of beta decay products emission,
3) induction,
4) and Lorentz confinement of charges particles.
The only component of his theory that is not proven is the stimulated emission of fast electrons (a cascade event).
f..k someone just took all of the thought out of my brain and placed it here:
http://www.free-energy-info.tuks.nl/McFreey.pdf
and that was after Lithuania experiment( with ferrite - means with  no eddy current  flow in one piece of metal as ferrite is made out of metal filings in billions electrically and mechanically insulated particles
I need to analyze it deeper....................... so far no comments.
Thank you
Wesley
AlienGrey
Quote from: apecore on November 22, 2016, 02:01:01 PM
Bat1Robin2,
My thought even further,...for instance using Rasperry or E_blocks  for control and measurement.
Making the whole system based on microcontrolling.
He, He! tried it with a pic, it will modify your code and do strange things, try it in a lead box !!!
AlienGrey
Quote from: GeoFusion on November 22, 2016, 02:12:22 PM
Try it, let me know how it works. ;)
28T  are same direction of 3T coil.
Edit*
Adrian guska's coil is 37.5m
18.75M 3 layer inductor.
enjoy.
Geo what if you fired both Fets at the same time like this ____¬___¬  at your 1.7mhz rate or do you think that's what's going on ?  just a thought.
AG
NickZ
   Conico:
   Adrian was using a 12v system, if you are going to use a 24v system, you'll need to make twice the number of turns, 12, and 12 turns. Or at least 8 or 10 on each side of the center tap, depending on who's set up you are going to try to replicate.
  My yoke is 12, 12 primary, 28t secondary, 3 turns (other) secondary, 24v system. All coils wound clockwise. When all coils are on, the diameter is 3 1/2 inches wide.
  Hoppy:  I just checked on my system, and there is a small change in frequency when the Kacher circuit is turned on, as compared to when it's not on. Slightly higher frequency is noticed. However, the voltage does go up substantially, with the Kacher's interaction.
No spikes noticed on my scope, even with no earth ground line connected.
   Verpies: Can you explain what you mean by using the magnet on a stick, to test what exactly?
I understand about the hand affecting things, but not sure what the magnet test would prove.
  Once I tune the yoke coil's frequency using a magnetite magnet on the core, I no longer hold it, so my hand is not near the device.
  I thought that the NMR resonant frequency needs to be much higher, than what we are dealing with on these devices. As the induction circuit is running at about 15-28KHz, and Kacher frequency around 1 to 2 MHz. Does NMR work at those frequencies?
verpies
Quote from: stivep on November 22, 2016, 05:31:06 PM
Be aware, that two versions of these papers exist.
1) Older, based only on NMR
2) Newer, based on NAR
