0 Members and 123 Guests are viewing this topic.
Hoppy
NickZ
  Verpies and All:
  The only interesting point (as far as I'm concerned) in one of the McFreely articles, is this one (below).
But, which like many of his other statements and ideas, he has not proven by building and showing an actual and working self running device.
  So, what would he be "bragging" about?
   quote:  NAR or NMR are not necessary in the process of energy extraction. What is needed, is a vibrating "energy-gain" material placed  in  an  alternating  magnetic  field, or in more general  terms, spinning and precessing nuclei periodically  displaced  from  their  equilibrium  positions  and  immersed  in a magnetic  field. Mechanical  resonance  is  not  used here  to  induce nuclear precession, the nuclei are already precessing.  The precession was established by the rising magnetic field.
   end quote.
   Yet, he ignores and does not expound on the effects that these pulses have on the surrounding ambient, and those resonating (re-sounding) effects back onto the device itself. Which is what I'm really after, instead of the nuclear decay derived from the "gain medium".
AlienGrey
Na! it's an ide but this guy desn't do it the same way.
Just watch
https://www.youtube.com/watch?v=zBqpeyIs8-E
T-1000
stivep
Quote from: NickZ on November 23, 2016, 11:08:13 AM
  Verpies and All:
   end quote.
quite intriguing  as long as I can remember , when ferrite starts to make noise "no one" of you guys thought about nature of noise, the very mechanism of noise, the very latices response  and form of this
response
Nobody of you I think thought about mechanical vibration of ferrite  dipoles as gazillions of small particles of iron( not always only iron but doping  of other materials) that responses according to Longitudinal Wave principals.
so think guys,
I'm just striping you and anyone else from ability to patent it ever  by posting that little  small set of words here.
Thank you NickZ and Verpies for joined effort in new frontiers struggle to give it to humanity..
That also means give it out to bunch of idiots, ignorant "fricken lambada  flat brains" who have no other sense of being on this planet   but to trash it , use it and abuse it.,
If some of you are offended with statement I say recycle yourself from trash to  the value respected by others who fly higher than you. Never equalize yourself with  level you belong  to.
I'm not educated in many areas ( medicine) But I'm not an IGNORANT to it.
The problem I  see  is that you tend to skip what I write unless there is money in it or personal  immediate gain  visible noticeably  at your perception  level . You want to be and idiot be my guest  go dance Lambada with bunch of other idiots.
However I'm OK with it.
Particles bonded in ferrite  starts mechanically move in this bonding compound.
Mechanical movement is slow in its response but slow "in  going to rest"
stimulating  forces are enormously fast.
electrical  or electromagnetic stimulating force impacts ferrite and
-if it is electrical than it is causing magnetic field around the conductor that is in Near Field to interact with  metal filings in ferrite  redirecting magnetic dipoles into ordered fashion response.
-if it is electromagnetic in Near field = the response will be near the same
Properties of single grain of  ferrite:
QuoteA ferrite is a type of ceramic compound composed of iron oxide (Fe2O3) combined chemically with one or more additional metallic elements
https://en.wikipedia.org/wiki/Ferrite_(magnet)
-vibration means movement of magnetic dipole that is switched to its newly set direction
-moving "magnet" ( the magnetic dipole known as magnetic domain) induces both  https://en.wikipedia.org/wiki/Magnetic_domain
a.  electric current in the conductor( and that can be the same conductor that was previously making mechanical and magnetic response of that grain!!in ferrite( magnetic dipole aligment)
b.  mechanical response of other magnetically active metals or other domains in within the same ferrite or ferrites in close field vicinity
Now we  are dealing with conflict of responses that can
a. add to concentration of energy but now mostly according to longitudinal wave properties ( and mechanical resonances)
b  subtract or  transfer  energy to  another form  e.g. electrical gain in the conductor in Near Field  with creation of  electrical resonances
c. if not tuned to utilize the responses it shows total losses and energy dissipation in form of heat.
And now we are ready for NMR to come to play...
The more  I think about Lithuania Experiment the more clear and consistent  is for me picture of energy extraction .
At this point  the little  addition of controlling force like  Neutron gun  or beta, alpha emitter could be sufficient enough  similar to mechanical analogy of the guy who suck fuel from the neighbor car tank using small tubing . All he needs is one single suck ( one impulse at the beginning) and than gravity  is doing  all of the job.
at the  end  the guy did not pay for fuel  and did not pay for  fuel flow. ( Tariel Kapanadze one impulse from battery)
The difference of potential  in electrostatic concept devices  according to my incomplete  as of yet Electrostatic Pump Theory
acts as a "bait" to electrons from the ground.
Motion is creative not  a balance . Balance is mostly form of rest and not a form  of work present http://www.physicsclassroom.com/class/energy/Lesson-1/Definition-and-Mathematics-of-Work
So if Electrostatic HV potential is delivered in impulses it creates electron response having significant inertia.( between the impulses)
Even if  mass of an electron is small than volume ( addition) of all of the inertial motion usually is manifested somehow e.g heat dissipated by that conductor  (increase of the current)
and here is interesting moment .
once we established that first impulse from battery( the first force) creates  current in the conductor raped around ferrite core,   than  if that is nano second impulse than it creates response from magnetic domains  of every  grain of metal in the ferrite. Than magnetic moment is flipping to align itself  ( you can even  hear it) ( you can dis-align it  with knocking it  with the hummer)
Now delta T of that mechanical response being slow has delay factor  in respect to fast changing  electrical impulses.
The delayed mechanical change gives with delay additional electrical energy than if that is coordinated with inertia of electrons flowing from the ground towards HV electrostatic potential  now we only need to find what that  energy to sustain  the motion is coming from..
- NMR?
Wesley
Going with that  somehow convoluted thoughts we can make answer  very quick of how to build Free of Charge  energy Device
