0 Members and 118 Guests are viewing this topic.
stivep
Incomplete  sentences just thoughts? ??? ??? ??? ???
axiom:
when ferrite that has temporary magnetized domains starts to vibrate than its mechanical  change of position - placement creates  mechanical movement of "magnets"- grains of ferrite
Motion of magnetic field induces current flow back in  the same conductor winded on this ferrite ,but with delay and different frequency - that current flow will be most likely non sinusoidal ( square  like) in shape
think of it that you have magnet in your hand and you move this magnet along  copper wire  and now you are making current flow in that wire
first impulse generator  used by Tariel Kapanadze was spark gap,.
than he changed it to high voltage  train  impulse generator from  gas furnace ( used to light up the gas in furnace)
than SR, Anonimus,Akula, Ruslan Andrian Guska  changed it to nanosecond generator.
that generator  can be  powered by any source  we do not have to pay for. alpha  neutron beta /// solar// wind//
That is our electron from the ground HV electrostatic voltage potential  generator
that generator is employed in the electrostatic pump "pumping" electrons from the ground
I'm going to make some addition as it is hard to understand
Think about wire connected to the ground
and it is connected to  one plate of capacitor
the other plate of capacitor is connected to antenna
The higher you are with your antenna the bigger is voltage difference on that capacitor plates.
that difference is stored in capacitor as potential energy .
Once this energy is discharged  by us -spark gap connected to  ( ferrite core with coil) it creates current flow in the coil.
that makes mechanical  switching of magnetic domains in ferrite
by that there is mechanical vibration taking place
by that due to that vibration the creation of  the delayed electrical current is made
the frequency of that   impulses is   equal to the frequency of mechanical vibration
that impulse is induced in the same conductor that was previously  magnetizing domains in ferrite,
Now we have presence of another much lower frequency  impulse in the same conductor.
that  newly created potential
Wesley
NickZ
   Wesley:
   What if... it's not the ferite vibrating, such as in Roma's device, as there is none, just his copper coils.
However, can it do what it does without even copper windings, as well? Maybe...if so then it must not be the copper, either.
Can it still produce the same 4000w output, using iron, aluminum, or some other wire coil materials? Maybe, as it may not be due to the "gain materials" used to decay, but to the unknown and unmeasureable gain medium (Aether, Ions, etz), instead.
  So, that can also brings us to the subject and study of what the interaction of HV/HF pulses along with low voltage higher amperage MAGNETIC pulses may be doing to the surrounding ambient, and to it's hydrogen ions, or isotopes, etz...
Something more to look into....
Grumage
My dear Wesley.
With the assistance of Verpies I did several videos looking at ferrite using piezo stimulation. Starting here....
https://www.youtube.com/watch?v=SPV89JWVdtY
Four in between....
Finishing here....
https://www.youtube.com/watch?v=2TTM414t_zI
It was however, 3 years ago, much water has flowed down the river of life!   ;)
With all best wishes, Graham.
stivep
Quote from: NickZ on November 23, 2016, 02:37:28 PM
   Wesley:
However, can it do what it does without even copper windings, as well? Maybe... then it must not be the copper, either.
Can it still produce the same 4000w output, using iron, aluminum, or some other wire materials? Maybe, as it may not be due to the "gain materials" used to decay, but to the unknown and unmeasureable gain medium (Aether, Ions, etz), instead.
  So, that also brings us to the subject of what the interaction of HV/HF pulses along with low voltage higher amperage pulses may be doing to the surrounding ambient, and to it's hydrogen ions, or isotopes, etz... Something more to look into.
are you talking about akula??>
Akula has got ferrite in his device.
but you might be right
where is ferrite in tariel  Kapanadze device?
very interesting....... everything in other guys is like Tariel but not ferrite.../
so  what we have in common to all of them
1. High Voltage
2. coils "granate"
3.one impulse from battery to start
4.  impulse interrupter known as :
a.  spark gap,
b. HV train generator from home home hot water  gas operated ignitor
c. nanosecond generator
5. ground wire
6. the more power device delivered the more capacitors or bank of capacitors is present
as far as ferrite wire... Tesla and in early wacky medical  devices soft  iron wire was used instead of ferrite tightly packed into the coils
later on  inventors created  silicon plates and than metal filings bonded with  epoxy created first ferrite cores
Wesley
NickZ
   Wesley:
   I just edited my last post, so please check it again.
   NO, it's the Roma device that does need nor use ferrite in the cores, (not the Akula device).
And Poma's device (image below) can still produce 4000w output. And it can do so without the need of an Earth ground line to work just as strongly, as any other devices. So, it is NOT the energy coming in from the ground line, either.
   Yet, TK's ferrite-less device(s) are another good example, as you just pointed out.
