0 Members and 124 Guests are viewing this topic.
AlienGrey
Quote from: Grumage on November 23, 2016, 02:39:22 PM
My dear Wesley.
With the assistance of Verpies I did several videos looking at ferrite using piezo stimulation. Starting here....
https://www.youtube.com/watch?v=SPV89JWVdtY
Four in between....
Finishing here....
https://www.youtube.com/watch?v=2TTM414t_zI
It was however, 3 years ago, much water has flowed down the river of life!   ;)
With all best wishes, Graham.
Hi please bear in mind the piezo device is a pressure wave device and therefore a longitudinal transmitting device !
Regards A G
lost_bro
Quote from: stivep on November 23, 2016, 01:19:25 PM
quite intriguing  as long as I can remember , when ferrite starts to make noise "no one" of you guys thought about nature of noise, the very mechanism of noise, the very latices response  and form of this
response
Nobody of you I think thought about mechanical vibration of ferrite  dipoles as gazillions of small particles of iron( not always only iron but doping  of other materials) that responses according to Longitudinal Wave principals.
so think guys,
I'm just striping you and anyone else from ability to patent it ever  by posting that little  small set of words here.
Thank you NickZ and Verpies for joined effort in new frontiers struggle to give it to humanity..
That also means give it out to bunch of idiots, ignorant "fricken lambada  flat brains" who have no other sense of being on this planet   but to trash it , use it and abuse it.,
If some of you are offended with statement I say recycle yourself from trash to  the value respected by others who fly higher than you. Never equalize yourself with  level you belong  to.
I'm not educated in many areas ( medicine) But I'm not an IGNORANT to it.
The problem I  see  is that you tend to skip what I write unless there is money in it or personal  immediate gain  visible noticeably  at your perception  level . You want to be and idiot be my guest  go dance Lambada with bunch of other idiots.
However I'm OK with it.
Particles bonded in ferrite  starts mechanically move in this bonding compound.
Mechanical movement is slow in its response but slow "in  going to rest"
stimulating  forces are enormously fast.
electrical  or electromagnetic stimulating force impacts ferrite and
-if it is electrical than it is causing magnetic field around the conductor that is in Near Field to interact with  metal filings in ferrite  redirecting magnetic dipoles into ordered fashion response.
-if it is electromagnetic in Near field = the response will be near the same
Properties of single grain of  ferrite:  https://en.wikipedia.org/wiki/Ferrite_(magnet)
-vibration means movement of magnetic dipole that is switched to its newly set direction
-moving "magnet" ( the magnetic dipole known as magnetic domain) induces both  https://en.wikipedia.org/wiki/Magnetic_domain
a.  electric current in the conductor( and that can be the same conductor that was previously making mechanical and magnetic response of that grain!!in ferrite( magnetic dipole aligment)
b.  mechanical response of other magnetically active metals or other domains in within the same ferrite or ferrites in close field vicinity
Now we  are dealing with conflict of responses that can
a. add to concentration of energy but now mostly according to longitudinal wave properties ( and mechanical resonances)
b  subtract or  transfer  energy to  another form  e.g. electrical gain in the conductor in Near Field  with creation of  electrical resonances
c. if not tuned to utilize the responses it shows total losses and energy dissipation in form of heat.
And now we are ready for NMR to come to play...
The more  I think about Lithuania Experiment the more clear and consistent  is for me picture of energy extraction .
At this point  the little  addition of controlling force like  Neutron gun  or beta, alpha emitter could be sufficient enough  similar to mechanical analogy of the guy who suck fuel from the neighbor car tank using small tubing . All he needs is one single suck ( one impulse at the beginning) and than gravity  is doing  all of the job.
at the  end  the guy did not pay for fuel  and did not pay for  fuel flow. ( Tariel Kapanadze one impulse from battery)
The difference of potential  in electrostatic concept devices  according to my incomplete  as of yet Electrostatic Pump Theory
acts as a "bait" to electrons from the ground.
Motion is creative not  a balance . Balance is mostly form of rest and not a form  of work present http://www.physicsclassroom.com/class/energy/Lesson-1/Definition-and-Mathematics-of-Work
So if Electrostatic HV potential is delivered in impulses it creates electron response having significant inertia.( between the impulses)
Even if  mass of an electron is small than volume ( addition) of all of the inertial motion usually is manifested somehow e.g heat dissipated by that conductor  (increase of the current)
and here is interesting moment .
once we established that first impulse from battery( the first force) creates  current in the conductor raped around ferrite core,   than  if that is nano second impulse than it creates response from magnetic domains  of every  grain of metal in the ferrite. Than magnetic moment is flipping to align itself  ( you can even  hear it) ( you can dis-align it  with knocking it  with the hummer)
Now delta T of that mechanical response being slow has delay factor  in respect to fast changing  electrical impulses.
The delayed mechanical change gives with delay additional electrical energy than if that is coordinated with inertia of electrons flowing from the ground towards HV electrostatic potential  now we only need to find what that  energy to sustain  the motion is coming from..
- NMR?
Wesley
Going with that  somehow convoluted thoughts we can make answer  very quick of how to build Free of Charge  energy Device
Good day Wesley,
Maybe I shouldn't rise to the bait:  but..............
Quote from: lost_bro on April 27, 2014, 05:00:43 PM
Hello All:
I believe this to be relevant concerning ferroresonance and dimensional resonance:
and in relation to AC power systems:
"Ferro-resonance can generate overvoltages of upto 12 times line to ground source voltage upon opening a single phase device or poorly synchronised 3 phase device. Voilent failure can occur exposing personnel to the high voltage failure and accompanying conditions. Ferro-resonance conditions can result in damage to lightning arresters, switching devices, buried cable, transformers and associated equipment.
Ferro-resonance can be initiated when all of the following elements are present and the switching means at the dip point or takes off when a single phase device or an unsynchronised 3 phase device that does not operate all phases within 1/2 cycle.
1.System grounded at the source, but with no ground at the transformer bank
2. Shielded cable length or overhead conductor length sufficient to create the capacitance necessary
3. Transformer size that permits saturation of the iron core at the operating voltage
4. Transformer unloaded or lightly loaded.
Prevention or control of ferro-resonance can be by:
1. Using wye-wye transformer withboth neutrals grounded and tied to systems neutral
2. Using only phase-to-neutral (not phase-to-phase) transformers connections for single pahse transformers.
3. Limiting length of underground cable
4. For poorly synchronised switching devices, extra resistive load of 2% of the transformer capacity on underground cable. "
Ref:www.tpub.com/doeelecsafety/electri... safety
Food for thought, and it does correlate with the Russian stories of the cores self-destructing after a short runtime:
take care, peace
lost_bro
Actually we had discussed in depth the relative possible origins of the *screaming* Russian Ferrites a couple of years ago.   The above was just one of my posts in relation to Ferro-resonance and *possible* related phenomenon.
This post was made during the discussion pertaining to Akula and his perpetual 30watt LED.  I really don't remember now if we spoke of this on this thread because the 'Grenade/inductor'-Tesla Coil does NOT use Ferrite.
take care, peace
lost_bro
NickZ
  Verpies:
  Concerning the suggested magnet test on the ferrite yoke core for observing if there is any NMR involved to my device. As I've mentioned and shown in my videos, I use a magnetite magnet in or on my yoke core most all the time. Yet, the reaction that I've noticed is an increase of output at the bulbs, higher output throughout the coils, and not a diminishing effect, as you mentioned. Although I can also adjust the magnet to do just the opposite, as well, but as that is not the idea, I tune for maximum output gain, using the magnet, instead.
  So, in relation to your suggestion of the magnet test on the ferrite yoke core, what are your thoughts and ideas concerning the above mentioned results.
AlienGrey
Quote from: NickZ on November 23, 2016, 06:25:26 PM
  Verpies:
  So, in relation to your suggestion of the magnet test on the ferrite yoke core, what are your thoughts and ideas concerning the above-mentioned results.
N M R National Milk Records ? I hate lazy terminology when you mean Nuk Mag Res !
Just get your Sig Gen on it and your Scope on the other end and see where the peaks are! anyway
not all Res fits all ! But your after a conveyor belt production line once you have it going.
In a way your spending your winnings and you don't yet have a ticket :D
The other thing is If there is no such thing as free energy or a free meal, where did the Universe come from ???
stivep
https://www.youtube.com/watch?v=r40h66qiF5I
βNMR at ISAC is about 10 orders of magnitude more sensitive than a conventional NMR experiment.
http://bnmr.triumf.ca/
http://www.brynmawr.edu/chemistry/Chem/mnerzsto/The_Basics_Nuclear_Magnetic_Resonance%20_Spectroscopy_2.htm
https://groups.nscl.msu.edu/becola/bnmr.html
The polarized RIB is stopped on a surface of a single crystal under a strongmagnetic, applied parallel to the polarization axis to maintain the polarization in the crystal. Anapplication of a radio frequency (RF) can induce transition of between adjacent Zeeman levels at the resonant frequency (Larmor Frequency
there is no need for complicated electronics  beta is beta and emits like beta
neutron emitter is used for energy production and for "making"  atoms  to decay
and that decay can be also in betas
to make  neutron "gun"  it takes few minutes of work
all we need is a self powered stimulator/power supply  of nano impulse generator
Wesley
