0 Members and 135 Guests are viewing this topic.
lost_bro
Quote from: forest on November 25, 2016, 11:27:34 AM
lost_bro
How this active miller clamp can be extended for two fets connected together to make bi-directional switch, which can work also wit AC signal ? I see the important to clamp signal immediately and in both directions, but the DC SSR's are slow.
Good Day  forest
I would probably need to see the schematic to be sure of what you are talking, but............
*If* the NMOSFETs are common sourced than the PNP transistors would be common emitter.
Use the basic configuration of the schematic which I attached to the preceding post.
I actually prefer to float a neg. voltage on the gate signal to the FET, but that usually requires an additional isolated voltage source.
Not sure if I answered the question you asked ;)
take care, peace
lost_bro
GeoFusion
Hi Guyz,
A Tip.
The power which is manifested at output at caps, as what I measure acts as reactive power.
The output voltage will drop slowly after applying load because of using what the cap has charged.
The merging/mix is what creates this at the end resonantly.
There is a video of Ruslan showing a Grenade without a Bif Inductor, which is fast charging one of the caps to
1140~ Volts and settles when looped  to 970~ volts with load attached. That is reactive power behavior.
Ions converted to usable is what is needed here for all of this to be success.
https://youtu.be/Qo4DkJnmCSM?t=290
My Motor cap can charge All the way to 315 volts when maxing but average 240V nicely.
its how I have it on the 40M grenade on bench.
slowly when adding load it will settle down to a lower amount of voltage but as shown does not effect input anymore.
Try to get Tesla/kacher to have maximum peak on Ion Gathering which will go on a iron plate which is connected to capacitor and then
to ground and in between a cap to measure with scope and when you have measured the best spot of it with scope,
you see freq and with the freq unit to calculate the wirelenght that is needed for  winds grenade.
EXAMPLE, a simple way to see this with Tesla Kacher and Grenade.
It's like 10meter diameter water pipe with High pressure flowing water coming out ( transmitter ) and you want to capture for what comes out.
Now if you use 5meter diamter collector pipe to collect the water,
only 50% is harvested and maybe less and other 50% or more is returned to nature.
So to make it balanced you need to make another pip collector 10meters diameter or bit larger to collect out most 100% of it.
So same thing now Applies to Tesla coil transmitter and Grenade receiver but  now in Freq Terms to resonate with wirelenghts.
This is one of the secrets I believe to be Which is very important.
After to have the best harvest, Only then the synchronization part comes in for low freq magnetic field to be generated and mixed with it.
A reminder that inbetween 2nd layer and 3de layer behaves as capacitor.
Is it the same as when I was talking about a plate with connection between capacitor and then to ground? ;)
think about it.
resonance.
  Cheerz~
lost_bro
Quote from: GeoFusion on November 25, 2016, 11:48:48 AM
think about it.
resonance.
  Cheerz~
Good day GeoFusion
OK, between 2nd and 3rd layer of Grenade......  is that where the winding direction changes from CCW to CW?
take care, peace
lost_bro
forest
lost_bro
verpies posted this http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg494989/#msg494989
It is essential and important to make it as fast as possible without complicated isolated gate drivers.
Is it possible to modify this circuit and use transistors and ultra-fast diodes to obtain the same result ?
Diag 3 on verpies post
forest
verpies
can you post examples of those anty-miller gate drivers ?
