0 Members and 157 Guests are viewing this topic.
NickZ
    Nelson:
   The reason that I said that it's only an inverter, is because once he feeds back some of the output back to the input, and shows it possibly self running, and hopefully not just on a tiny bulb like he is using, there can be possible meter measurement errors.
   His input source is a 12v, 7ah battery. His output is only lighting a small bulb. There is plenty of room for error.
   I have never seen neither Akula, Ruslan, nor anyone else showing "more out than in", ever.  Is that really a prerequisite for self running? I don't know, but I'm trying to look for a cause and effect to these devices. And after my over 3000 posts on this subject I'm still looking into it.
   NAR and NMR may also be a possible cause for the same or similar "amplification effect" from these devices, or maybe not, but, it's also on my plate to analyze if possible at this time.  It may involve the same effect, but, not due to nuclear decay of the fuel materials source, but to something else instead, such as Earth's magnetic resonant effects, as the gain medium.
   I've also been trying to raise my output voltage, as most of us are only showing a very low efficiency inverter, which is not leading to self running. So, I'm now converting the outputs to DC, which may be a step in the right direction. Or maybe not. However, I am working on finishing up another new full bridge rectifier, that will go on the output side to the bulbs. As that is what it may take to raise the voltage at the output, (possibly at the expense of the existing amperage). So, that I can see if that helps, or not.
   There seems to be many different ways to obtain a self running device, many different schematics to study, also. It can all get very confusing.
   My system is built somewhat like what Igor is showing, using a similar ZVS magnetic circuit, and a simple Kacher for Hv circuit.
But, I'm using a Tv yoke instead of the flyback core for the magnetic circuit transformer. I had previously also used the flyback core, on Geo's type of MRG tests, which was also based on the ZVS circuit like Igor is now showing.
   Igor has not shown a self running device to date, nor have I. Hopefully that will change in the near future.
   If there is anything new and exciting from your experiments on these self running systems, we would love to hear about it...
You can also PM me if you prefer.
                                                NickZ
nelsonrochaa
Quote from: AlienGrey on November 27, 2016, 07:44:43 AM
Yes Nelson ;) nice to see you here again Nelson, If anyone here decided to do some homework there is plenty of documents telling you the theory on how the device works and many others, Only look.
Hi AG,
For sure you have right about that ,is only read  because information are available , but aplly that information  most of time is other story , because even small details make huge diference . So just read it will not enougth for sure to understand how to apply in practice need to sometimes have some luck and persistent . ;)
Have a nice day
AlienGrey
Quote from: NickZ on November 27, 2016, 09:53:31 AM
    Nelson:
                                                NickZ
Nick nothing like confusing yourself and others ! don't you get it?  The inverter is an accelerator ! but your  just letting yourself be modulated inside the sine wave energy frame, not outside it. It's all over the internet ! your sheltered in here from time and reality, look outside the box.
nelsonrochaa
    Nelson:
                                                NickZ
Hi Nick ,
Yes ! Is that my point ! Until know the system that people are working at present moment is even close a full effiencie inverter like you told . Way should not be a requesite show more out than in ? Is not what everbody search ? To me seems logical .
Some months ago i refer a lot o times that effects that are showed by ruslan and akula could be reproduced in other ways . That is way most of anounced "free energy" devices most of time have some simillarity between them.
All the roads goes to Rome . And several ways could be used to achive the goal . If you think well every that devices have something in common in their work operation  is not curious ? I know that you and lot of people already think in that .
A self runner device is not a free energy device , but a more convenient way to convert and produce currents in a self sustaining oscillation circuit where the output is capable to produce more work (W) and provide the enought power to sustaining the circuit until "main power input" is depeleted or interrupted.
And in a system like that  you could find at first eye that have several Stages in that system  not only one circuit.
So is important study many diferent aspects of all Stages envolved.
Igor show important aspects but must be understood  only that , and should not be desconsidered because in my opinion is important and easy to understand what he try show.
About news nothing new ;) only some small improvements and some changes in hv stage ; im learn everday how to improve many aspects of system like you and other guys . I retain one important thing  :  we should have more precaution with what we dont see then what we see and think is aparently more dangerous .
Take care .
Hope see progress updates very soon  by everbody envolved
Cheers
NickZ
  Nelson:
  You mentioned, "Way should not be a requesite show more out than in ? Is not what everbody search ? To me seems logical."
   Yes, it would seam logical, but, is that really the case?  As it has never been proven, as a prerequisite to self running, at least as far as I've seen. Although some guys may disagree, but without any proof towards that end.
   It may not be correct to compare a closed system to an open system. Nor to expect the selfrunner to only self run until it has used up it's external (battery or other source) of input provided to it. It would not be "self runner" in that case. Such as is the case with NMR. As it should only require a one second kick start to activate the selfrunning process. After which, it should not need nor use any other man made input source. Especially IF NMR or NAR are not providing the additional energy source through nuclear decay of the gain materials used. Which is still an unresolved issue, and which needs further testing to prove, one way or the other.
