0 Members and 313 Guests are viewing this topic.
Ed morbus
stivep
Update:
In regards to the special ferrite from russian TV Rubin( yoke)
I'm moving forward with lab testing equipment.
the biggest problem    for me was  that I  did not want to spend  money frequently for Liquid Nitrogen to cool down   number  of  devices that have detectors operating in temperatures below -196 Celsius
I also have  cryogenic vacuum chamber  operating with LN2 ( liquid nitrogen)
and second helium cooled  test chamber that     operates at temperature near intergalactic vacuum space  4K ( kelvin)
4 Degrees (Kelvin) = -269.15 Degrees (Celsius)=-452.4700
so quite close to absolute  zero -459.6700℉
EDXRF,  HPGe, and number of spectrum and mass spectrometers was just taking my  floor space.
In science it takes years to collect necessary instruments just to progress one step up.
this will allow me also to test in cryogenics behavior of materials and elements of  "Kapanadze" like devices
While you guys are working with  make it happened I work with the biggest unknown yet..
What the energy comes from and what is accurate   process of energy conversion in these devices.
I hope we make it happened together.
I was never to much fan of superconductivity but  once I have it than I can use it.
the goal is?........
screw them all big time........... you know who.............
Wesley
Grumage
AlienGrey
Noice on this video Nelson is demonstrating how the tone goes higher as the energy increases.
thanks for the demonstration !  ;)
https://www.youtube.com/watch?v=_YIuUrubUfQ
NickZ
  Yes, due to the higher frequency. Main peak is seen at about 10kHz, there are several other lower and higher frequency peaks as well. As seen on my audio spectrum analyzer. It would be good to compare with Nelson's scope readings, also.
  Good luck Wesley testing the yoke cores, and the source of additional or extra energy.
  My feelings are that circuit running efficiency has very little to do with self running. But, that correct running frequencies and sycn are what's responsible for making up for the losses. I also plan to prove this, as well.
