0 Members and 703 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on November 27, 2016, 12:09:59 PM
    Alien Grey:
  Please show us how your device is "accelerating" itself to self run. As I wouldn't want to confuse you, nor anyone else. As there is much information about this subject on the internet which amounts to nothing. As you seem to think that you are not so "sheltered", here, as you claim that I am.
   But, you're right about one thing, the accelerating part,  I don't get it.  Please prove your point, by showing it. This is not about CERN.
   No need to get personal, nor insulting, while not showing much of anything yourself. Sheltered, or not...
Nick I,m not intending on insulting you if i had i would be better at it, 8) I have made many mistakes but as time goes on bits of information and technical secrets come to light, I have been experimenting with a high voltage generator, spark gap device I'm experimenting with very encouraging results, one thing is it produces tremendous heat in no time from little input current, as I said it's an accelerator using at present a Royer sine wave (sort of) oscillator. One strange thing I have noticed is it's intolerance to power supply rise times It tries to destroy the driver transistors unless dumped on a read up and running supply..
I had to wind the high voltage transformer in sections for insulation as E and I type just S/C and burn out at 3kv.
Hoppy
Quote from: nelsonrochaa on November 27, 2016, 09:51:14 AM
Thanks by your observation , and that is true if we want to go deeple , but watts sure is enougth to ilustrate how could be the rĂ¡cio of input vs output , do you agree ?
Thanks
If at a glance you saw a voltmeter reading an input voltage of 12V and ammeter reading 1A and a voltmeter on the output reading 120V and ammeter reading 0.2A, would you automatically assume that the DUT was running overunity? If after a few minutes you glanced that the output current fell to 0.1A and the input readings and output voltage remained the same, would you then assume that the DUT was 100% efficient?
NickZ
    AG:
   I understand that you're not really being serious about the "sheltered" part, nor anything else. As about the only thing that I'm really being sheltered from lately, is the ongoing tropical storm called Otto.
  Some times I can be overly sensitive to some comments. I hope you understand.
  As I've mentioned I use a version of the Royer circuit, known as the Mazilli circuit. Which is also an induction circuit design.
You may find some interesting information in the link below. Concerning controlling any excess heat built up, as well as some other information concerning those types of designs and systems.
   Still, I see no "accelerator" in this type of circuits, so I don't know what exactly you may mean by that.  Just the workings of a normal but simple and effective push-pull induction circuit. Somewhat similar to what Igor has now shown on his video.
  I have been able to effectively light up to 700w worth of bulbs using this circuit. Without burn-outs. Nor needing fans on my oscillator. However, I did notice some over-heating issues at higher loads, previously, when I neglected to add the needed 0.68uf capacitor, at one point of my earlier tests.
   Commercially made Mazilli ZVS circuits are also available, with up to 1000w output. However, they don't incorporate nor have any duty cycle nor frequency controllers, so I've had to develop my own ways of getting around that. As I had not seen any OU nor self running effects, from the SG. You may want to try the Roma type device, that needs no SG, nor ground line.
  I was hoping that Itsu would have a change of heart, and give Roma's circuit a try.
   http://www.rmcybernetics.com/projects/DIY_Devices/diy-induction-heater.htm
Ed morbus
PolaczekCebulaczek
I ask again and for last time... IS THERE ANY CHANCE OF SPECIAL INTERACTION (energy wise) BETWEEN EMF AND ELECTROSTATIC E FIELD? After all, we can do all sort of crazy things with EMF, and waves (kacher ,grenade coils,bucking coils, resonant mumbo jumbo twisted standing waves and so on),just look at tesla "fireball machine", ball lighting or impossible back then but not now EM drive? are UFO's real? if so how do they work? UFO has to be an free energy device that also has no mass (if we ever extract EM energy from atom without splitting it apart then atom probably will loose its mass) ARE WE INVENTED EVERYTHING? I'm interested with electrostatic mixing theory in this devices but if this is energy from ionosphere then its fine. I just cant believe that our civilization will end because of empty oil can.
Could we have missed something important in basic EM theory?
