0 Members and 157 Guests are viewing this topic.
forest
Here is what we overlooked:the same coil powered by the same DC power source gives more magnetic field with proper core.
We missed simple scientific fact : magnetic field is the source of energy.
T-1000
Quote from: nelsonrochaa on November 27, 2016, 12:13:04 PM
https://www.youtube.com/watch?v=_u81edIeqIY&t=97s
Hi Nelson,
Would you mind to share your step-down inverter circuit which is only partially discharging  caps(just my guess about this one is being used inside of right box) ? Also does it look on HV caps charge level to make sure the caps are not being drained too much with nanosecond pulses?
This would save time on design and debuging on such inverters.
Cheers!
AlienGrey
Quote from: Ed morbus on November 27, 2016, 06:27:41 PM
watch GTA1183
TL494 12V 200V
nice inverter accelerator but how do you convert it to an E-CAT collector with output ?
PolaczekCebulaczek
QuoteFirst I must specify the relation between  phenomena.
Than I need  based on that relation specify  possible interactions
And than I need to apply usable by us interaction to mechanism that would "work " for us.
Wesley, perhaps something along those lines https://www.youtube.com/watch?v=G6mmIzRz_f8 but
to "speed up" not a particle but a wave. One more thing... what do you think about a "reversed electromagnetism" if real than what could it be? and can I destroy EM wave?
Hoppy
Quote from: nelsonrochaa on November 27, 2016, 11:08:28 AM
A self runner device is not a free energy device , but a more convenient way to convert and produce currents in a self sustaining oscillation circuit where the output is capable to produce more work (W) and provide the enought power to sustaining the circuit until "main power input" is depeleted or interrupted.
Cheers
Nelson,
Could you please explain this sentence in more detail? I think you mean that your self-running device has an oscillator which is fed from a power supply which receives feedback from the output of the device until the power supply is depleted or interrupted?
