0 Members and 146 Guests are viewing this topic.
stivep
https://youtu.be/mz9NRYQJJt0
Quotedeslomeslager2 hours ago
After he removes the 9V battery (3:02) there is a period of time no sound to be heard, and then we hear the high voltage beep sound when he connects the feedback!
He quickly disconnects it, but the HV beep continues several seconds until he connects the feedback again. (do note: the fan in box 1 is not rotating during this period)
But he did not yet connect his battery yet!
So either the video and sound are out of sync, or it was not edited correctly.
Or? Or the 'experiment' has failed partly, because we now have proof there is a voltage coming out of the feedback even without the battery connected. I think any 'experiment' should be without any doubt.
This video has a doubt. Mine in particular. I don't believe in these Kapanadze devices until
I have seen one myself (but I'd rather see it being replicated by dozens of men all over the world).
this note will sound convoluted as I repeat myself few times  right below:
at 3:05 the sound is suddenly activated by Nelson trying to connect selfloop  between  two boxes  for 13 seconds.
The sound started when Nelson start to make connection,
Than Nelson disconnected two  wires and tried to connect them back.
But the sound was still there despite all of that.
It is for me clear that for that moment  charge was delivered from capacitors We may assume that  no stored energy should be left in the capacitors to even  make for the 13 seconds of discharge.
The end of that sound was almost rapid cutoff....
When Nelson  in 1:47  connects battery for the first  time  the fan in the left box start to rotate( no sound)
In 2:27 Nelson pushes the switch of the second box ON. from that time both boxes are connected together.
In 2:42 fainting  sound  shows sloping discharge of capacitor under the load and the same again
in 3:00 We assume that all charge was  at now dissipated .- nothing left in the capacitors. ....................>>>
Over sudden we hear sound for 13 seconds  during re-connection  3:05 . despite interruptions in between.
The sound comes from left side box so the assumption is that charge  was delivered from the right side box and it was sufficient enough to make sound from  left box .
The puzzling is that rapid cutoff, however it could be explained by lack of load  during reconnection, ( the gate  of transistor cutting off due to   gate voltage requirement)
I would say it is normal.
Right side box capacitors  have been also charged and hold charge independently  till the time of self loop reconnection.
The biggest puzzle is what energy  came from  to charge capacitor and hold load  power  requirement at 300 to 600W in any time frame. So I do not suspect Nelson but I just do not have answer. to that question.
Wesley
Quoteshubus5 hours ago (edited)Curious device.
Doesn't look like a Kapanadze relative.
No large Tesla-like coils, no Russian TV yoke-looks like a normal one-- and contains many, many more parts
Yes it does not.
And this is very good.  there was no earth connected to the device. so earth like  effect could be done with counterpoise.  like with an groundplane antenna.
The 10cm coiled antenna of your car uses as balance  metal body of your car.
it is not important if you have straight wire of 2m=144MHz resonance Frequency or you have it  as a compressed coil.
The physical length is what counts. However  efficiency of such antenna is different and bandwidth is more narrow.
So anyone of large transformers-like coil could serve as  such ground.
There is  to little for me information so far to  be able to  say something more about the nature of  this device
Wesley
AlienGrey
Quote from: Hoppy on November 28, 2016, 01:15:26 PM
Nelson,
Could you please explain this sentence in more detail? I think you mean that your self-running device has an oscillator which is fed from a power supply which receives feedback from the output of the device until the power supply is depleted or interrupted?
It's in simple einglish, is it not ? the output is fed back into the input to power the oscillator until it is interrupted, so if that happens the loop is broken, thus end of loop, LIGHT goes out ! derr!
Hoppy i'm sure if you put your mind to it you could make such a device your self with all your experiance :D
good luck.
nelsonrochaa
Quote from: stivep on November 28, 2016, 01:16:58 PM
But the sound was still there despite all of that. It is for me clear that for that moment  charge was delivered from capacitors We may assume that  no stored energy should be left in the capacitors to even  make for the 13 seconds of discharge.
The end of that sound was rapid cutoff....
Wesley
Hi Wesley ,
I apreciate your opinion but is not my itention make videos every time somebody put any questions or doubts about how  work this system, is not a opensource by now .
but i left one shot made to answer at your doubts about if the output on feedback have power already or not .
https://www.youtube.com/watch?v=_7zWwJBcTHc
That demo circuit is not full assemble and not full finished, even in their max output ;  have two connections to two external bank of capacitors; one of 100,000UF 450V  and other to a 32V 500F bank of supercaps ,  but that bank's are not connected yet and will make all the difference in final output. In some months this unity will be tested in a electric car demo project. I have some delays in last months with some health problems in first demo circuit,  like i told you in PM some time ago when i ask you help . But i'm ok now , and work again :)
hope you the best
Cheers
stivep
Quote from: nelsonrochaa on November 28, 2016, 08:20:45 PM
Hi Wesley ,
hope you the best
Cheers
Thank you Nelson.
I believe I differ much from any  other folks I know.
The priority for me is science of energy conversion.
I do not care much about  anyone secrets, I'm  very much satisfied with my present life.
I do not need to make money on FE.
It has somehow come to me that I can activate at least 3 millions people around the world before they multiply by themselves. So my  YES  matters to many a lot. And I cherish this  credibility very much.
If I was to invest my money and my connections  to get  my hands on the device I would have it in my hands long time ago.
And I know that this statement may upset many of you guys.
Instead I have one of best equipped privately own labs dedicated to energy conversion movement in US.
It is just a matter of priority in life.
I can not drive two cars at the same time , live in two houses,  and  have headache from women I could interact with. :)
I have only one lifetime and I want to have fun, pleasure and entertainment and all of it  I found in science.
I have no stresses, no problems, no aggravation, no credit cards, no leases, ...... and not to much money to go wild. :)
I'd better do not mention value of my quipment if purchased new as it would be shockingly  hard to swallow it to many  of you.
Because of that approach to life and life values  quite few wealthy people and a lot of scientists around the world  decided to help me to "collect" my lab for just small fraction of that value.
So message to anyone :
You want help to prove to the world    that you got   outstanding results, ??? ???
I need to see it and say YES....
And I believe many doors opens up in front of you.
That is why  Akula ,  Ruslan, Adrian Guska are so much in fear for me to visit them.. or reverse.
I promise them no business with me, no money paid, and I would know  how it works by looking at  it after so many years of experience with FE.
Nelson I do thank you very much for your work. It would be a pleasure to meet you some time in the future. :)
Keep your secrets to yourself, I do not need  to know it.
There never  be any investor in your device.. ever.
But there may be  billions of buyers..if you just listen to me without me being  involved.
Kapanadze ,SR, Anonimus, Ruslan, Akula, Bedini,  Stanley Meyer, Carerra...   got  nothing. No one single name you can list......
I got something they possibly never had......
Beautiful life......
Wesley
Hoppy
Nelson,
Thanks for the measurements video. Best wishes with your electric car demo. No more questions from me.
