0 Members and 79 Guests are viewing this topic.
Meta
In other words Nelson is using the parametric oscillator principles of HopeGirl and her fathers QEG oscillator and the ring resonance of the toroid, with the principles of Gerard Morin, namely the low voltage step up (3D) of a McCullogh 1500w genset, to the high voltage horn on transformer 1 to high voltage horn on transformer 2 (4D) then a step down to low voltage to a 7x load (3D), that Gerard Morin demonstrated in one of his videos, only Nelson is just using electronic components.
apecore
Thanks bro,
Finally we have the answer.
Greets
Jeg
Quote from: Hoppy on November 29, 2016, 03:19:53 PM
Although he says there are no cap banks connected, that does not confirm that there is not an internal pre-charged high farad cap or caps, or even battery, sufficient to provide enough power to light the lamp for the short period shown.
Hi Hoppy
We deal with selfrunners and so it's been implied that there is not any source of energy other than this 9V battery which kick-starts the process initialization. By process i mean the amplification of energy.
....and provide enough power to sustaining the circuit until "main power input" is depleted or interrupted."
By that statement, what i understand is that if you connect a load at the output which dissipates power at higher rates than what system uses to charge its capacitors, then system can not self sustain its own operation. The same happens if "interrupted" by a switch which stops the feeding back to the start. (Depleted or interupted...)
But again only Nelson is authorized to speak about his devices. If he has time i am sure he will clear it out. ;)
magpwr
Quote from: nelsonrochaa on November 29, 2016, 07:55:56 PM
Hi ,
You have right about that , but even i make a shot showing you las patas :) of favor  it will enought  and i understand that .
Im not sell anything , even and dvd with a guide like i see lot of people doing :)
Cheers
hi nelsonrochaa,
Don't mind me asking.Can your device run for 48hours at least non stop without suffering from "stability issue" after couple of hours.
AlienGrey
Will someone PLEASE explain why it is so important to some predators on here, why it's so bloody important for someone to develop an original device that has to be a self-running and published, it's entirety on here ??????
I don't mind giving or helping anyone but taken for granted for financial gain other than making a contribution then !! bolux  ;D
Wikileaks explanation of oscillator
https://en.wikipedia.org/wiki/Parametric_oscillator
PS my Skye no longer works, account wiped out thanks
