0 Members and 39 Guests are viewing this topic.
AlienGrey
Quote from: d3x0r on November 29, 2016, 04:15:42 PM
Ya I was looking through his history too
https://www.youtube.com/watch?v=GmlpV1MWm40
Looks pretty simple - so I dug up a toroid I had, and a signal generator, and put a coil through the toroid and measured various output... I eventually got a higher power generator, and attached a transistor and higher voltage (better power through the dirving coil) because it is a LOT of turns.  I ended up sitching the drive to a much lower turn coil on it (like 24 turns) and was getting higher signals on output....
What I found generates the best sort of output with a coil through a toroid is to run current for a short time through the toroid, then stop the current for a long time.   The resulting oscillations in the dead space transfer energy best... like typically your highest transfers are at the swtich on/off of a pulse... but this was well after the switch time...
Don't be fooled by what you see in this vid
It works by the author charging that big cap up first but the transistor Mos Fet bias is just below conduction, he just pulse the gate with a small static charge and 'walla' the circuit bursts into life ;)
AG
Hoppy
Quote from: AlienGrey on November 30, 2016, 07:25:01 AM
AG
Agreed. Take another sweet lad! That's roughly the same working principle as his big boy device.
Zeitmaschine
Quote from: magpwr on November 30, 2016, 06:55:18 AM
Don't mind me asking.Can your device run for 48hours at least non stop without suffering from "stability issue" after couple of hours.
I think this depends on the capacity of the hidden battery. ;D
Could be in the black box with the high voltage label. 8)
OU by means of a lot of electronics always indicates that something is fishy. :)
Hoppy
Quote from: Jeg on November 30, 2016, 06:47:17 AM
But again only Nelson is authorized to speak about his devices. If he has time i am sure he will clear it out. ;)
Hi Jeg,
To clear up whether Nelson is really self-sustaining output without depletion, the acid test would be for Nelson to run the same two-box device for the full duration of a max length video, with a meter clearly measuring the voltage across the lamp load and with as before, pre run good close-up camera shots all round the device.
magpwr
AG
Quote from: d3x0r on November 29, 2016, 10:15:42 PM
It works by the author charging that big cap up first but the transistor Mos Fet bias is just below conduction, he just pulse the gate with a small static charge and 'walla' the circuit bursts into life (http://overunity.com/Smileys/default/wink.gif)
AG
hi Aliengrey,
I beg to differ from all the rest.
I do suspect the circuit of nelson which contain "a unusually huge resistor" may conceal a hidden AAA battery.
It's just a joule thief circuit which requires a kick start via the ignitor.
This theory of mine is highly probable but take note it may not be 100% accurate.But do consider the hidden possibilities. :D :D :D
I wonder what say Hoppy related to this matter. ;)
