0 Members and 74 Guests are viewing this topic.
AlienGrey
 Let's get back to basics any one notice Mr Kapanazie's device has one or two spark plugs pulsing a huge EHT spark, you  don't think that device has anything to do with it, DO YOU ?
Anyone know what thread spark plugs are, I have one of/ for a lawn mower it says it's 10mm but it's much finer than that, I want to attach it to a bracket with another back to back. ???
The transformer is a 9 segment device 9 x 300t pri and 9 +9 sec with a half farrite  rod Ariel core, the diodes are 800v 3a s fast pulse type with 1n 6kv caps.
AG
10 mm fine metric, will try and get a set, plugs are far better than transistors as the depletion layer can leak across, depending on bias voltage and PN junction.
AlienGrey
Quote from: magpwr on November 30, 2016, 08:59:46 AM
hi Aliengrey,
I beg to differ from all the rest.
I do suspect the circuit of nelson which contain "a unusually huge resistor" may conceal a hidden AAA battery.
It's just a joule thief circuit which requires a kick start via the ignitor.
This theory of mine is highly probable but take note it may not be 100% accurate.But do consider the hidden possibilities. :D :D :D
I wonder what say Hoppy related to this matter. ;)
that's right it is a jewel thief circuit, but what about that 90-degree coil on a slug, some kind or resonant feedback coil, may be, tops up that cap somehow, before it runs out of energy ? I did ask him but didn't get much back. But he is a good man at heart, a bit like yourself  ;) 8) :D.
AG
Grumage
Quote from: AlienGrey on November 30, 2016, 09:07:28 AM
AG
Dear Mr AlienGrey.
That question I CAN answer very easily....  ;)
Most spark plugs are a metric fine thread, usually 1mm pitch in all cases.  You would need to buy a cheap tap from someone like Tracy Tools who offer a range of Carbon Steel taps at very reasonable prices.
Having built and restored many IC engines I have a full set of HSS taps and dies from 10mm through to 22mm.
Kind regards, Graham.
Hoppy
hi Aliengrey,
Hi Mags,
As I've said previously, its most likely that there is a hidden source of energy. This could be a battery or very high farad caps that could sustain an output for the short duration the lamp was shown illuminated. If a battery, I think it is probably lithium based and larger than an AAA.
AlienGrey
Quote from: Hoppy on November 30, 2016, 10:02:45 AM
Hi Mags,
Hoppy I seam to remember Nelson saying ihat he used a High cap device he also said it wasn't over unity. Ask him again I'm sure the will help you out!
