0 Members and 108 Guests are viewing this topic.
T-1000
Quote from: verpies on May 24, 2013, 11:26:24 AM
Neither Hoppy nor I are speculating endlessly.
Last several posts were about obtaining the details of the circuit and its waveforms.
Information gathering is not speculation.
Awaiting for your test results then :)
Hoppy
Quote from: forest on May 24, 2013, 10:07:31 AM
http://www.youtube.com/watch?v=KgBdrHeZ1rE open your eyes
do you see why it can make difference ?
Most definately! Especially if he manages to dispense with the batteries and run it on caps.  8)
NickZ
  quote from Verpies:  Concerning Woopy's scope shots.
  "It was a mistake to take that voltage waveform reading without a resistive load in place of the light bulb.
  Well maybe it was, but this was the path that UFO politics used to get his motors working in a very unconventional way. UFO is also able to light several huge 85watt CFL bulbs, giving many lumins, as well, using what he calls "COLD ELECTRICITY". (the green flashing Cfls).  The main thing is the circuit, and how it may be  similar to what Akula and others may are doing.
I'm looking for clues...
   Woppy's scope shot are meant to show the tuning of the circuit using the two pots and scope, to find the sweet spot, although that is somewhat conventional, the ultimate results are not.
   I use a light bulb to show me the same thing, as I'm not concerned as to what frequencies are shown by the scope. Having the two trim pots is a great advantage though.
  Tinsel:  Thanks for your analysis of the akula devices. That is the point.  Those pictures are fairly clear.
And yes, I'm guessing as to what the diode values are, the point was the current direction as they are pointing towards each other.
  Menof:  Using the single Fet (in woopy's video) is similar to what you are showing in your diagram, it is a simpler version, to look for the working principals. It also shows that a single Fet will work fine, also. Although he is not showing any real gain by it all. That was not the point  when he made the video.
  Maybe one will not see the input readings drop until there is a feed-back path.  Or not?
NickZ
  Cepren B:
   Did you find the honey pot yet?  I got my spoon...
Quote from: Hoppy on May 24, 2013, 05:14:49 AM
Maybe intended to 'sharpen' the gate pulse leading edge as sometimes used with bipolar transistor switching. Not needed with mosfets. Could these be IGBT's?
Could be, I have no experience with small IGBTs, just big "bricks" designed for hundreds of amps. I can't read the part number on the parts in the photo, unfortunately.
