0 Members and 232 Guests are viewing this topic.
SolarLab
FYI
Considered a significant milestone toward understanding and quantifying an "engineering approach" thus leading to an actual  "design and implementation" of these types of energy generating devices.
The following is derived from the work of Вячеслава Горчилина (Vyacheslav Gorchilin) http://gorchilin.com/?lang=en
An example Standing Wave analysis on a Tesla Coil (L/2 - 1/2 wavelength) [mathematical]:
Win    = 66.68    Wout = 3111
Kn2 = 43.881      Normalized:   Fundamental = 100  Phase = 180    Second = 50  Phase = 90
Sample at zero crossing (green bar before T/2)    D=0.01     P=1%
     This example has NOT been OPTIMIZED in any way. It is for informational purposes only.
STABLIZED Analysis (computer simulation run for about one hour in web browser):
{Note the sample time is changed to the first zero crossing and appears to give a bit higher Kn2}
  [see attachment for snap shot]
=> link not exactly transferring correctly - therefore adjust the simulation settings in the browser to suit.
Reference:
&Ph=[3.14,1.57,0,0,0]]http://gorchilin.com/calculator/pull?T=0.06&L=0.5&D=0.01&P=0.01&G=[1,0.49,0,0,0]&Ph=[3.14,1.57,0,0,0]
Standing Wave animation snap shop (1/2 wave, high Q):
Reference:
http://gorchilin.com/calculator/longline?L=0.5&Q=200&g=100&g=44&g=0&g=0&g=0&ph=90&ph=0&ph=0&ph=0&ph=0
Vyacheslav Gorchilin, and others, have provided a very interesting analytical design "start point" !
Thanks very much to you all!    "It is, in fact, intuitively obvious to one Skilled in the Art!"
Attached: A related (translated to English) article by Victor Grieg, August 2010
entitled "electron" referred to in one of  Vyacheslav Gorchilin's references [6] in Russian here:
http://gorchilin.com/articles/energy/pull?lang=en
Also known as:   Principle of operation and practical advice on manufacturing CE device "a la Kapanzdze."
Snap shots are attached as well, but embedding them within the text may not work - whatever... not going to fuss with that at this point.
Now it's on to the analysis, design and verification stage based upon a logically sound theory (mathematical proof - postulation).
     Can not find attachment to resize - sorry :o(
FIN
nelsonrochaa
Quote from: Hoppy on December 02, 2016, 11:20:23 AM
Here is what I've so far deduced through the glass: -
You will recall that Nelson said his device was not running on free energy. That leaves the distinct possibility that there is an internal source of energy that he may have found a way of maintaining through feedback, or not. The RHS box in the demo contains a transformer connected to a push-pull which operates as a simple inverter, with the transformer secondary winding appearing to drive the halogen lamp directly. The push-pull is connected to the LHS box with the black link cable seen at the back between the two boxes. The likely source of power could be contained in the black box with the high voltage sticker on top. The halogen bulb is likely a J-class low voltage (36V) R7s, Notice how bright the lamp shines on first connection and then dims down with a voltmeter reading of around 36V. The inverter transformer secondary output voltage is likely being pulled-down by the current draw. The other unit in the RHS box is a cheapo Chinese PSU with its lid off, purpose so far unknown. The 9V battery operates a relay which starts the device.
Hi Hoppy you are losting qualities in your deductions  , where you see 36V ? Where you see a push pull ?
Why you say that is a 36v bulb do you want a analog meter connected to you see better the output voltage  ?  The light is a 240v 120w halogen and  dims because the stronger of the light  is cuted by camera :( not droping like you say , see well .
The relay not start the device too :) i can asure that , have other function not put the circuit on  . I could do vídeos to refute all your deductions because you miss in  all your observation . I Will tell you why.
1 - this system that you see , i not develop to be self sustain and  is not that the goal of in this  system. I just try to  show that  without "amplification" no feedback could be asured like i try show .
This system i designed to be feeded by a small input source like a 30w solar panel  or other small current source starting at  1v until 60v and the goal is provide a high voltage high current output  some (kw) to be used in  a EV electric motor under acelleration, not to work lighting bulbs and be feedbacked  .but could be used like i show in this vídeo .
2- the output where halogen is connected have a 600v max output voltage and the current trains is limited by the capacity of high voltage caps , and that is the reason to i say in other post that  is not  wet connected the final bank of high voltage caps  8*10.000uf 450V , the internal capacitors are smaller in their capacity . The capacitors are not previous charged , and if you pay atention in second vídeo i try show that measuring the dc voltage present in caps when 9 volts is connected and when is removed but seems not understood in that way , i know i could produce better quality  videos show step by step all the points , but im not a youtuber that live of their profit of by donations :) so we need to live with i put available :) because i share without waiting  receive nothing by anyone ;)
3-No push pull in system i could garantee that to you : ) i realy dont get it where you see that .
Is a own design topologie not a push pull or other knowed comercial configuration ,  that i can asure to you because i study  many topologies to understand some points and  to compare my own designs and is very  diferent of most topologies used in switching ; and of course i know what is push pull :)
I can ear some people claiming about circuit have lot of electronic . Why should i used that components if i dont need then ; only by funny ? Only to be nice ? Everthing have their function in circuit .
4- The relay that you hear only work asure that one of stages only will start work when some minimal value in voltage is  achived in hv caps is their function in system , so when you hear the relay almost 180v is charged is hv caps before caps start discharge in other stage of circuit . The black box is a capacitor bank, that is charged with BEMF from smaller smps transformer ,the Yellow one .
I know that you will ask other questions , but  i will not opensource anything until i finish the actual project , i respect my compromises , and only to your information i have a hard task to convince my supporter allowing me share some of last vídeos , in last months in my channel respecting some conditions . So you i could say to you that i have intent in future consider opensource some of my ideias but not by now , need to focus in my actual project to able to test the system full assembled  ;) in some months and in that time i will judge about the system and if they  work :) that is my main concern.
Cheers
Acca
Nelson thanks for that clarification on your device as much speculation has been done..
Thanks !
Acca..
Hoppy
Nelson,
As I pointed out at the beginning of my post, I just deduced or more accurately guessed the function of some components. This was primarily in the hope that you would respond by correcting me, which you have and I thank you. It is now clear from the further details you have given us that you do appear to have something rather special in those boxes! I apologise for coming across as being over critical but I am of the opinion that if a device is important enough to demonstrate by video, then it should be done in such a way that viewer understands what is being shown, at least the function of each part / module of the device and where measurements are being taken from. Unfortunately, your video did none of these things.
I wish you every success in your venture.
AlienGrey
Quote from: Hoppy on December 03, 2016, 05:23:57 AM
Nelson,
Hmm it's just your opinion in the end, and the word 'audacity' comes to mind! it's just a form of intimidation, Nelson has told you he will most likely reveal details later on when he is ready why can't you just leave him in peace or he might just walk away completely, or is that what your aim is ?
Further information, some of you would do well to familiarize this posting on the energetic forum.
http://www.energeticforum.com/free-energy-frauds-pseudoskeptics/19985-defamation-character.html
AG
