0 Members and 232 Guests are viewing this topic.
justawatt
i found a patent from china ,which is very similar to don smith ,tesla style. Brief setup 220volt to high voltage using tesla coil and
use capacitive divider connected to coupling coil to take output (where the resonance freq of tesla coil = to capacitive divider)
may be the capacitor don smith used is working as capacitive divider.
there are 4 figs ,in the patent , is there any site to search chinese patent and get the diagram. Please some get us the diagram
Power amplifying device
CN 104753358 A
https://www.google.com/patents/CN104753358A?cl=en&dq=resonance&hl=en&sa=X&ved=0ahUKEwjJqaysz9fQAhVFLI8KHbTFCJc4ChDoAQhoMAk
A power amplification device which is the transformation of the existing series resonant voltage tester, an increase of Zen closing coil, the magnetic field as the extraction equipment possible. Pressure tester from the series resonant frequency voltage power supply, excitation transformers, reactors, capacitive divider, capacitors; coil of Zen in the original reactor two coils wound thereon, as energy output ports; a capacitor instead of the original tested capacitor connected in parallel with the capacitive voltage divider, together constitute the LC series resonant circuit capacitor
AlienGrey
Yes a good find, I found one in English I sent the link to Nick as he kept waffling about a self-starter device, ask him to post it to you it showed everything and told you how it works to, I don't have the link now my machine doesn't keep links if i just turn it off ;) and it did just that after i sent it!
lost_bro
Quote from: justawatt on December 03, 2016, 02:25:17 PM
CN 104753358 A
Good day justawatt
Found this;
take care, peace
lost_bro
lost_bro
Good Day All
Just wanted to report an interesting update which *might* answer some questions that were raised about a year ago here.
I have converted my SSTC (SolidStateTeslaCoil) to run off of solar.  Well, I use an inverter and 12V deep cycle battery for the power supplies.
On my YouTube channel I posted a couple of videos sometime last year:  SSTC Ground Current; https://www.youtube.com/watch?v=RUEBzjiGLPs
and SSTC Ground Current 2;
https://www.youtube.com/watch?v=wysm0Zxpz5k
In these videos I was using the Public Grid as my power supply.............. and a few people rightly asked the question:
Will the light bulb light-up if you run the SSTC from an ISOLATED power supply?
MagPwr at the same time presented a video where he lit-up an LED thru inductive coupling using a small Ferrite toroid.
Tonight I finally got around to running the SSTC from my Solar battery powered ISOLATED inverter.
For who will ask, my entire house runs ONLY on PhotoVoltaics (solarpanels).  I do NOT have a Grid connection at the house.
The inverter in question is COMPLETELY isolated from Ground............. meaning the inverter does *NOT* use a ground connection anywhere in it's circuit.  No ground  loops here ;)
So, I wound up a small HF choke toroid, (the type for common mode chokes, etc.) and placed 5 parallel one watt *straw hat* White LEDs wired in series through a 220ohm resistor and wrapped only 1 turn of 22awg wire around the toroid.
Have attached photos of the test apparatus.
The toroid / LED / resistor combo was placed on the *far* end of the 10awg. GROUND cable (ground cable put through the toroid), which is about 5 meters distance from the SSTC when operating.
The LEDS light up super bright............  whenever the SSTC is discharging the LEDs are on.
I do realize the LED can be made to light up by very little current, and soon I will find a small incandescent AC bulb, like I used in last years videos to try the test again with Solar power supply.
The *Grounding* of the base end of the Tesla Coil forces the 1/2 wave coil into 1/4 wave operation yielding a voltage node & current antinode at the grounded base connection.
This likewise renders a Voltage antinode & Current node at the *far* end of the the 1/4 wave resonator (usually the end with the aluminum toroid).
Considering that the Voltage antinode is at *ground potential* it should have ZERO volts...........
but this is obviously NOT the case.
The *Ground Cable* is demonstrating *real power* (some part of it must have voltage & current in phase) as it can light-up 100watt incandescent light bulbs.
It is late tonight and I did not take a video.  I will make a video of this with the Toroid placed over the Iron bar used as the ground rod and post it soon.  Also I want to find another Incandescent Light Bulb and redo the Ground Current video with the isolated power supply for the SSTC. Should prove interesting.
take care, peace
lost_bro
P.S. Jeg; I will answer your questions in your last post A.S.A.P.
Acca
 Here is some links to the crappy dangerous exploding Russian TV's from the 1980's to the 2000 it is real and these things explode and catch on fire ..
The Yokes are the culprit as resonance makes the Russian ferrite to generate power from a nuclear event..
I am making a prediction that the iron ferrite cores from the Russian TV "Ruby 714" which was 120 pounds in weight was a beast ! in more than one way !!
Do as you please..
The noise of the yoke is in the sub-audible range (ultrasonic) and in the very high pitch as only Russian dogs and cats where driven mad.. The ferrite core that Wesley used in the 2010 was that type .. links provided below and a Russian forum about TV explosions in Russian..
February 01, 1987
Shoddy Color TV Sets Dangerous, Soviet Paper Warns "MOSCOW — Watching television in the Soviet Union can be fatal.
The Komsomolskaya Pravda newspaper said Saturday the number of fires caused by defective color television sets that explode totaled 5,490 in 1985, and some of those fires were fatal.
"Statistics show that with every year colored television sets become even more dangerous. In 1980, a total of 2.26 million sets were manufactured and 2,126 fires were reported. Five years later, the number of fires caused by television sets reached 5,490 out of 4.2 million manufactured. People were killed and buildings burned down," the newspaper said."
The newspaper said the model most likely to explode was the Rubin-714. It said manufacturers have blamed the problems on the poor quality of plastics and picture tubes used in the set.
video of the Russian deadly TV. Now listen all allot of Russians died from these deadly TV's it's no  joke !!
https://www.youtube.com/watch?v=yJCRKS6DbHE
https://www.youtube.com/watch?v=gqMv4H6z3Hw
Description
"Ruby 714" - TV 2 class unified, tube - semiconductor.
The main technical characteristics:
- Frequency range - 80 ... 12500 Hz;
- Power consumption - 250 watts.
Weight: 60 kg.
description of that Exploding Russian Color TV
https://translate.google.com/translate?hl=en&sl=ru&u=https://ru.wikipedia.org/wiki/%25D0%25A0%25D1%2583%25D0%25B1%25D0%25B8%25D0%25BD_(%25D1%2582%25D0%25B5%25D0%25BB%25D0%25B5%25D0%25B2%25D0%25B8%25D0%25B7%25D0%25BE%25D1%2580)&prev=search
Russian forum talking about the old exploding TV's
http://forum.ixbt.com/topic.cgi?id=15:67477[/font]
and stories of the Russian TV's being very bad for you health..
http://www.tandrag.com/transportblog/croziervision/archives/002559.html
http://www.globalsecurity.org/military/world/russia/tv.htm
http://www.videokarma.org/archive/index.php/t-145996.html
Acca..
