0 Members and 242 Guests are viewing this topic.
justawatt
yadi.sk/i/Cdhuq3hCrGweh
не ищите БТГ.(его нет) ищите волновой назовем так - процесс. взаимодействие колебательных контуров по приему волны.
http://realstrannik.com/media/kunena/attachments/2718/DSCN0044.JPG
http://realstrannik.com/media/kunena/attachments/508/%D0%92%D0%90%D0%94%D0%96%D0%A0%D0%90%D0%92%D0%AB%D0%A5%D0%9E%D0%94.jpg
AlienGrey
do not look for BTG (not) looking for the wave is said to be so -. the process. interaction of resonant circuits for receiving the waves.
Is this from Igor device ?
d3x0r
@magpwr (only because I know you have simulator experience....)
How does an AV plug work in a simulator?
If a voltage to one side of a capacitor requires a current through the cap and out the other side, how does the current flow?
I tried a few things.... (falstad sim)
but adding other capacitance around the diodes or to a ground to simulate capacitance in the wires does not help?[/size]
magpwr
Quote from: d3x0r on December 04, 2016, 09:46:08 PM
hi d3x0r,
I don't recomend using a virtual environment to test out certain circuit like:Av plug,ferrite and etc.
But i did create something similar and simplified 1 wire flash circuit powered by 1x AAA battery few years back as posted in my youtube channel :Sanjev21
Avramenko plug -One wire supply automatic flashing ver 3.0 -Final version
http://www.youtube.com/watch?v=YG5zUKOrboY
boonk
съём с резонансного контура не нарушая его. типа как у калабухова только проще
Нужен токовый контур и качер. Контур 400 кГц качер 4 МГц. Ток в контуре 250 вольт и около 12 ампер. Настройка на биение частот как в видео. Можно делать на сердечнике.
https://yadi.sk/i/9ZRL-aIYtx3Ng
"material removal without disturbing it with a resonant circuit. type like Kalabukhov only easier I need a current loop and Kacher. Circuit 400 kHz Kacher 4 MHz. The current in the circuit is about 250 volts and 12 amperes. Tuning in to the beat frequency in the video. You can take on the core."...
