0 Members and 256 Guests are viewing this topic.
AlienGrey
Jeg
Quote from: boonk on December 06, 2016, 04:10:26 AM
съём с резонансного контура не нарушая его. типа как у калабухова только проще
Нужен токовый контур и качер. Контур 400 кГц качер 4 МГц. Ток в контуре 250 вольт и около 12 ампер. Настройка на биение частот как в видео. Можно делать на сердечнике.
https://yadi.sk/i/9ZRL-aIYtx3Ng
"material removal without disturbing it with a resonant circuit. type like Kalabukhov only easier I need a current loop and Kacher. Circuit 400 kHz Kacher 4 MHz. The current in the circuit is about 250 volts and 12 amperes. Tuning in to the beat frequency in the video. You can take on the core."...
Hi boonk, thanks for sharing. May I ask, what is the frequency inside your current loop?
AlienGrey
Quote from: Jeg on December 06, 2016, 09:57:48 AM
4 mhz ???
Jeg
Guys need some help on an oscilloscope reading.
When I probe to any signal frequency, the waveform is always steady looking, without trembling or moving when triggered right. But when I probe a pulse train output as a result of two 555 mixing, waveform moves right and left, trembling, even if I tried all my available trigger options. It is about 390Khz at 20Khz intervals. Is it something that I need to adjust on my rigol? It looks like a continues phase changing. When I open it in time and zooming down to one or two pulses on the screen, everything steady again.
verpies
That's normal behavior for two unsynchronized oscillators.
