0 Members and 273 Guests are viewing this topic.
citfta
There is something about that circuit that doesn't make sense to me.  In the lower right there appears to be an inverter circuit that takes 12 volts DC and converts that to 220 volts AC and that is fed to a bridge rectifier that changes that to 310 volts DC.  What is confusing is then the 310 volts DC is apparently connected to the center tap of the transformer on the left of the drawing.  So what is powering the transformer?  Transformers don't work on steady DC power.  Is there something missing from the drawing?  What do the two outer legs of the transformer connect to?
AlienGrey
Quote from: magpwr on December 10, 2016, 08:07:45 AM
hi AlienGrey,
Looking back at what i posted jan 2014.I am having a good laugh because the answer to the Akula old kapanadze device related to the harmoncis was there in front of our eyes.
But i took a longer harder way to decode by looking at old Akula videos.
Please do ignore the superimpose circuit.It serve no purpose at all related to 50hz/100hz  and high frequency in kapanadze.
I do wonder if anyone was observant enough to understand in old video Akula was using  high voltage dc from A/C 220volts inverter to power the
tesla coil(resonant at 3x the input frequency ~50khz.Input frequency is matematically related/follow tesla resonant frequency) and kapandze coil via the 3 turns from yoke.
The coil in yellow is  the tesla coil.Please refer to the attachment.The cylinder is the Antenna (Aluminum foil at the top spotted from old Akula outdoor video but can't see inner foil)
Static to current converter device.
Is static is called a ether back then.Classic English terminology?
If anyone experimented with pwm circuit using high voltage DC250volts for my case as shown in my older video.I have revealed at around 50second into video that output at 3 turns is around 192Vpp.
PWM Generator runs on 1xLi-ion battery and works with 250VDC
http://www.youtube.com/watch?v=cGRPKNhC_TE
Continue from above if you observe in Akula oldest video related to kapanadze he was using around 28turns from yoke instead of 3 turns from yoke to power the kapanadze coil using only
variable dc supply.
Using around 28turns from yoke to power kapanadze coil would give around 200Vpp as well.
Long story short-3 turns from yoke was used only provided if high voltage dc is available.28turns from yoke was used to power kapanadze if lower dc voltage is used.
Prove-This is the first Akula kapanadze video demostration before the outdoor self run video.The mini kapanadze coil is placed at the bottom in the middle of pvc for the outdoor video.Tesla coil was wound first and then the mini version of kapanadze coil wound over.
Akula0083 - Transformer in the air Video - Demonstration
http://www.youtube.com/watch?v=ccEX4H3D2IA
This the only video which reveal Akula was using 28turns yoke if  using low power supply instead of 3 turns from yoke to power the kapanadze coil.
Parametric oscillator is a requirement for the new device.Assemble yourself.No hints. ;D
Think about it why high voltage capacitor was used to power kapanade coil from yoke and why high voltage ceramic capacitor rated around 2.2kv was used as part of the snubber circuit for the IGBT.
"Please do not use TVS diode if we need to block high frequency from effecting the IGBT gates".It's the simple reason why Akula used dual Zener diodes for each IGBT since the zener got a poor response time compared to TVS diode.Harder to explain in one sentence. :D
But i find that ferrite beads at IGBT gates also does a good job at blocking high frequency noise.
That's all for 2016 from me.
Merry Christmas and a Happy new Year.
I think  Grumage built this device I wonder if he will re-look at his device ?
Also the coils l5 to L9 I 'm not too sure how they are wound but won't they have to matched with a transmission line device ? is that what his spectrum analyzer is for ?
Grumage
Dear Carroll.
Perhaps the schematic attached might shed some light upon your observations?
Kind regards, Graham.
citfta
Thanks Graham,
That clears up the confusion.  Much appreciated.
This particular subject is new to me.  I have a lot of catching up to do.
Carroll
Grumage
Quote from: citfta on December 10, 2016, 11:31:11 AM
Thanks Graham,
Carroll
Hi Carroll.
No problem.
For any newcomers visiting here's my video.
https://www.youtube.com/watch?v=LOqjTHmmumU
I was creating so much RF that this video was the second attempt, it froze the above at the end, just the audio continued to work...
Cheers Graham.
