0 Members and 69 Guests are viewing this topic.
lost_bro
Quote from: verpies on December 15, 2016, 07:12:32 AM
That depends on the Q of the LCR circuit.  As Q approaches infinity, the "min. delta in Freq." approaches zero.
I don't think so because the presence of an external AC oscillator negates self-oscillations.
Here are three videos for newbies:
http://youtu.be/zO7RZZW0wSQ
http://youtu.be/Mq-PF1vo9QA
http://youtu.be/ozeYaikI11g
Good day Verpies
Quite right, forgot to mention how the 'Q' (quality factor) 0f the coil/system ties into the equation.  Accordingly, like you say: Higher the 'Q', less Delta required for the needed flipping action at the Fres.
"I don't think so because the presence of an external AC oscillator negates self-oscillations."
In relation to your statement above, here is an interesting antidote:
"1. The coil was connected only through the full bridge rectifier with high-speed high- amperage diodes with fast recovery times. Coil is 40m Grenade.
2. It is necessary for your device to work properly use only ½ period from Tesla (Katcher) work. Otherwise the Tesla will take away what she has gave back!!!!
Therefore you should put the high-speed high-amperage diode (or parallel diodes) from the Earth-Grounding to Grenade end (40m). Akula did it on at receiving side.  It's cuts off one half of sine on the reception side.
Further important:
The diode on a reception side of the Grenade coil remove ½ half-cycle sine and thus we swing  oscillations without slowing down them by negative period of Tesla. Too many people doesn't know it and continue roll molding. That is why Roman (Akula) has said that grounding consume some power... That's right!! Because it, he zap pulse at  ½ period on reception side which is grounded. It is visible on all his devices! I long guessed why he was applied that method and understood that because is so simple and so easy – just  select properly  HV diodes. As any kind of  interference at such frequencies like in Tesla case will lead direct to not correct operation. In other words to cut off a half-cycle not it will turn out. A Kapa resolved this issue by a spark-gap and rectifiers on LF frequencies. There it is simpler and simpler, but it need more wires.... On the German device, Akula used small diodesl, Tesla ws far away, his cable grounding was long. By the way it is equal to Tesla secondary length!!! You shoudn't forget about grounding.... On this device it is the main thing and without good support (grounding) WILL NOT WORK.  Again you shouldn't forget that in this device dangerus high voltages and high currents  were obtained. As you know, HV moves even in the air. For this reason quality grounding is simple necessary part. Plus correct standing-wave (filed)resonance and most important safety...."
This is translated and paraphrased from an interview with Ruslan.
Apparently Without the Diode(s), the entire functional concept is a No-Go.
This seems simular to half wave rectification..... maybe Uni-polar pulses.
Could this be the key?
take care, peace
lost_bro
lost_bro
Hello Verpies;
Ok, running with that line of thought:
Could the HV pulse emitted from the Tesla/Karcher antenna have sufficient effect on the High 'Q' resonant point of the Secondary Grenade/ Inductor circuit that it causes a very small shift in the Fres for just a couple of nano-seconds?
If the delta is sufficiently small enough, that could trigger near-resonant *flipping* action needed to get the parametric oscillator effect happening.
take care, peace
lost_bro
GeoFusion
Quote from: lost_bro on December 15, 2016, 11:37:19 AM
Good day Verpies
Further important:
take care, peace
lost_bro
Hi Lost bro :)
Yes, Finaly......someone is starting to see it :)
that is part of the key, The negative period (1/2 period wave) is cut off by the HV Ultra fast diodes
You only need the Positive halve from Tesla. You only want to call in Ions ( radiant energy )
and not to remove it but to store it and use it in the flow of the spin.
Ground will provide the negative charges. The Tesla will take away what it has givin if full period is done.
Other part  of this is all the correct tuning of the coils Wavelenght and  Freq match.
https://www.youtube.com/watch?v=1weV296sjHU&t=1s
Many have already seen this one but, there is even Ruslan which commented on my video :).
over here I have done this with the diodes removing 1/2 period and is as real as it gets.
But kacher Tesla was not yet perfectly tuned to grenade But, when measured
it was on the 1/3 of the wave lenght of the grenade's
resonant freq. This is why it works on my bench. the manifestation.
It's on one of the harmonics of manifestation.
Radio Engineering skills is required here. Period.
I have currently a second setup now with exact measurements of wirelenghts for the travelling waves
Which is now under experimentation and there is super positive results now and complete different behavior
and could really say, it looks like how ruslan has shown it on some of his videos back than. :)
I will soon enough show some demo's when i'm done.
Exciting times ahead now :).
I think there is enough info now and everyone if comprehended well, now do this right,.
Cheerz~
lost_bro
Quote from: GeoFusion on December 15, 2016, 02:24:25 PM
Hi Lost bro :)
Cheerz~
Good day GeoFusion
Thanks for the confirmation...... I will be waiting to see your *new* video.
Hope you can post a final schematic as to where the diodes are exactly installed.
Quote from: lost_bro on December 11, 2016, 08:01:36 PM
......... I am more interested to learn how to calculate and stack/superimpose the waveforms generated by the Grenade windings.  I believe this is the needed/missing information.  Please note that Akula has a Rigol815 S.A. on his bench, it can be seen in his videos.  And Sergey has a Short Wave transceiver with digital display next to his device to test the frequency response in his videos.  Ruslan owns and operates a Radio Station, which it is said that he built and does service on himself.
What does all this have in common?
It's not just blind luck to set up one of these devices. These people are *skilled in the Art* so to speak.
They understand Radio, VSWR, transmission line theory, and have the equipment to build and test the appropriate circuits....
take care, peace
lost_bro
Take care, peace
Happy Holidays
lost_bro
apecore
Good day Lost_bro,
Thanks for your explanation,.... i can see now enough light in the darkness to find the door ;D
Also Dog one and Verpies,.... as i said before "Golden team"
You all doing great work on the theoretical approach.
And yes,.... hope to see Geo's "new" video soon.
Greetings
