0 Members and 308 Guests are viewing this topic.
Hoppy
Quote from: verpies on December 17, 2016, 11:24:30 AM
I think most people on this forum have a cat. I wonder why?
It maybe that the cat's are re-incarnated engineers and technicians to motivate and guide us to success!  ;D
apecore
Quote from: lost_bro on December 15, 2016, 11:37:19 AM
Good day Verpies
Quite right, forgot to mention how the 'Q' (quality factor) 0f the coil/system ties into the equation.  Accordingly, like you say: Higher the 'Q', less Delta required for the needed flipping action at the Fres.
In relation to your statement above, here is an interesting antidote:
"1. The coil was connected only through the full bridge rectifier with high-speed high- amperage diodes with fast recovery times. Coil is 40m Grenade.
2. It is necessary for your device to work properly use only ½ period from Tesla (Katcher) work. Otherwise the Tesla will take away what she has gave back!!!!
Therefore you should put the high-speed high-amperage diode (or parallel diodes) from the Earth-Grounding to Grenade end (40m). Akula did it on at receiving side.  It's cuts off one half of sine on the reception side.
take care, peace
lost_bro
Good day,
I hope we will not get off topic regarding the grenade and its parametric oscilation parameters.
Now we have Nelsons_led selfrunner on screen.
It is related in some kind.
With other words,..  i hope we can use it to continue the parametric Grenade discussion in which we reached some theoretical breakthrough.
Which makes it all engineerable
So in order to continue that research;
Quote from: lost_bro on December 16, 2016, 01:19:20 AM
Don't know if that counts, unless the HV pulse could travel back to the Yoke core/coil windings through the Grenade windings.
Indeed it could.
Conico,..  and also i have noticed that push_pull frequenties gets different by activating the kacher,.... (without gate spiking)
Thus also this means as Lost_bro pointed out that the frequenty matching of inductor/series Cap/ 3 turns coil is critical and maybe the final goal to get the EMF from the kacher continously at the same moment/ position in the induced grenade wave?
ps,...  i don't have a cat,...  my girlfriend has one and he doesn't like HV 8)
Greetings
conico
Yes , the frequency of Push-pull (on the load) will be doubled if you are at resonance and start Kacher.
Tom wants to go outside
conico
Can someone tel what Ruslan say about right to left and show with his hand? at minute 2. 30?
https://www.youtube.com/watch?v=ZTOrWiQ1rJ4
verpies
Quote from: conico on December 17, 2016, 12:42:35 PM
"it is important to establish a magnetic field inside this winding".  The reciprocal movement of his hand refers to the expansion and contraction of this magnetic field along the axis of the grenade.
