0 Members and 31 Guests are viewing this topic.
Hoppy
AlienGrey
Quote from: Hoppy on December 28, 2016, 01:45:36 PM
OK. Thanks Geo.
Geo Hi one question I have to ask, while I was doing some experiments I noticed a lot of heat from my original grenade coil wound with PVC insulated cable on PVC drain pipe ;) (cheep job) I was wondering how or what did you use to wind your device on ?
It might be an idea to use a postal tube but i don't think they supply in small quantities.  Other wise the unit will die of short time sag and i wouldn't wish that on any one  :D
Tomtech29
Quote from: Jeg on December 28, 2016, 11:00:15 AM
Hi Tomtech
Can you describe with a few words how does he modulate his output? I speak about the attached video. Thanks
Hi
As we see the arrangement of the circuit kacher we have two kinds of operating mode:
- One of them is known as the multiplier voltage number of consecutive windings and the number of windings is reduced frequency and vice versa.
Thick wire coil primary winding CCw a secondary winding Cw , while the lower portion It has a positive pole (which it is a permanent positive power source) while a negative portion thereof is broken.
in short, we get oscillations where we see the form of a sinusoidal signal near the coil.
- the second mode : obtaining electromagnetic field (would compare to the concert stage where the microphone is placed near the speaker called a loop feedback) :D
in the case inverts the polarity of the primary winding,but that's not all it is also necessary kind of loop conduit extending inside the tube "I guess that is part of the drain current" Let's go back to the primary coil
the number of windings is not accidental by reduction of the gap between the windings tune the length wave , On the oscilloscope we see the nature of the modulation commonly called fish
We will also need use a radio receiver will serve as a monitoring or detection,should be able to hear the squeal at a given frequency.
I realize that my description is unprofessional excuse me I tried but I is not getting for the better :D
Does anyone of you has already carried out this type of experience and what do you think?
Hoppy
Quote from: GeoFusion on December 28, 2016, 11:43:02 AM
Hi Hoppy,
Mains earth wire is completely disconnected from PSU 24V in the recording. Only Phase and Neutral are used to power it.
Ground ( Earth ) is another pin of 0.5M in.
Even asked a cousin to bring a  Back up UPS for the test last night, not connected to mains, just from backup battery operation.
Ground connection of UPS was as well disconnected. It as well and getting the awesome results.
Geo,
If you are able to use the UPS again, try raising or lowering it to various heights above ground with wood blocks or cardboard boxes to fine tune / vary lamp brightness.
AlienGrey
Quote from: Hoppy on December 29, 2016, 05:25:20 AM
Geo,
Hoppy are you going to put yours in a tree house or use it on a hover craft ? :D I know ask him for a guarantee !  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
