0 Members and 289 Guests are viewing this topic.
stivep
  https://www.youtube.com/watch?v=sweXFKSXMxo&google_comment_id=z131yltgetbsfjvbb04cc1czcti3hblyrm00k&google_view_type#gpluscomments
preamble:
No-one from you for so many years ever tried to explain processes taking place in  kielbasa of SR or grenade of TK and its clones..
  statement :
1.for every period of shifted  square impulse there are two resonance needle like  peaks  in bifilar with two ends are connected together.
2. physical space of neighboring windings is pin point affected .
3. if we will be talking about SR kielbasa with ferrite beds than twice per period it is change of magnetic domains in the ferrite
4. wire inside kielbasa should  act like  one wire transmission line. with dying longitudinal wave but  if speed  of it per 1ns is  calculated it will be possibly around few meters. That longitudinal E is important to us as it should obey properties of  mechanical wave that is also longitudinal. like squeaky acoustical sound of the ferrites. At the certain point there  is sweet spot.
go to links  at my video and  read more.
5 Sound of vibrating ferrites in SR concept is a must!!!
6. Tariel used spark gap for the reason described below
Question given to Wesley:
QuoteQuestion:
Wes, we can cancel b field around non inductive coil(yet current still flows and 0 inductive reactance), can a non inductive coil have a resonance properties only in open circuit? just thinking... also is out of phase "current" capable of running resonance in open system? (single wire)
Quote: The magnetic field created by one winding is therefore equal and opposite to that created by the other, resulting in a net magnetic field of zero In electrical terms, this means that the self-inductance of the coil is zero.
Inductance is the property of an electrical conductor by which a change in current through it induces an electromotive force in both the conductor itself[1] and in any nearby conductors by mutual inductance.
My understanding is that  when bifilar  coil that has two ends connected together ,  at the end of grenade " kielbasa" winding and is  covering only part of that grenade than  the rest of non balanced  winding  marks an  area   in space where  inductive  reactance active.
Only in that marked space inductive reactance along with magnetic field  are able to induce current in neighboring windings    as far as resonance- even in non parasite  resistors  winded  bifilar inductive reactance is not totally eliminated .
So it does have traditional  resonance frequency  where both capacitive and inductive reactances are cancelled. Another words   in series resonance the only present component of impedance is physical resistance of the  conductor- at that particular resonant frequency only.
What is interesting  is- the beginning and ending of  impulse in the form of  square  or rectangular,  If it was top  of the impulse we are talking about  than it  IS IMPORTANT TO US  TO KNOW THAT IT DOES HAVE MANY SINUSOIDAL COMPONENTS  OF DIFFERENT FREQUENCIES TO MAKE THIS SHAPE BUILD . ?The top is for us  or looks for us  like DC the leading edge and falling edge  is pure  AC . The same will be with  DC from battery that is interrupted . You will have AC in the same places of that impulse.
One or more of transversial components of  AC  will possibly work for us with  that self resonant( parasitic) frequency.
So than we will make two resonances at the beginning  and at the end of square impulse .
By regulating  rise and falling  edge time we are regulating the very parameters of that two impulses.
So think of it in bifilar like :
-the start impulse,
- than when the voltage is at max -there is nothing  no inductance no magnetic field but capacitive reactance  is still present(hmm I need to  think about it)
-and than falling edge impulse.
Now if bifilar winding is done from two layers of thick foil with insulation in between  than capacitive reactive component is magnified  by that the voltage  increases dramatically.
One of thoughts I just have is  an experiment where two layers of foil are  connected together at one end and than connected in series with  wire (coil) that is not bifilar .
That not balanced wire will act like coil to induce current in that neighboring coil in area or region of that coil.
The first very "capacitive bifilar" will only make two impulses per period and wire coil will make constant  transversial influence on other coil.
And this is what Tariel Kapanadze was trying to achieve using spark gap -when  variety of frequencies are present in spectrum from very low to over 1GHz
He was not worry where it will trigger with one of its components a desired impulse activity in the  grenade .
All the time there was  always one  present. and ready for him to interact.
Later on he switched spark gap to spark generator from gas  heating stove. The HV impulses  have been ready for him already in train of impulses generated by that module. If you take one and put it on spectrum analyzer you will see  noise signal  made  of many frequencies.
TK problem with spark gap was that  it was not steady. The maximum  of that spectrum was drifting and from time to time  spark gap was in need to be adjusted.
The coaxial cable used in device that was presented to me  was used like shield connected to inner  wire at the end of that coaxial coil and the surface  of shield with inner wire created  also capacitor.
At the certain point there was one wire that was injected to that coil  and I assume there was also few punches in that coax to make  from it leaky feeder that increases number of harmonics or parasite components .So the bottom line is that  wide spectrum of sinusoidal impurities is a must.
The subject you have touched is very interesting I will  make  more comments  on this
material to look at:
https://en.wikipedia.org/wiki/Inductance
https://en.wikipedia.org/wiki/Bifilar_coil
http://www.token.com.tw/pdf/resistor/wirewound-resistor-knpn.pdf
14:01  ,   15:05  ,  16:08    ваша проблема состоит в том, что в В России хороший английский язык не настолько популярен. Никто из Вас не заметил самые важные аспекты этого видео  Есть много их там..Я указываю только на немногих из них в этом комментарии.Я тронут русской ревностью, что американ движется быстрее, Ваша проблема состоит в том что, когда Вы делаете кое-что, что Вы говорите об этом и никогда не выделяете это и, не зарабатываете деньги на этом.  Мои друзья из России это видео идет о SR и форме откачки энергии от земли.все здесь говорит о транспортировке энергии  возьмите  глаза в  руки. Вы должны изучить английский язык Уэсли США
places to look at  in this video are  market  by numbers above in minutes
14:01  ,   15:05  ,  16:08       KLICK ON THE NUMBERS one by one
This video was not made to introduce you to  one wire transmission, but to create more of an explanation of electrostatic pump driving Tariel Kapanadze device and other people clones
Please do not listen to that part of video  but read.- the explanation is in the text.
it took me approximately 1 day (10hours) per every 4 minutes of this video to make it, and yet , no body find  in it ...
It is not important if I'm right or wrong..........The idea is important , the new approach.
There is no commercial  on my videos.. no benefit expected no money to be made
but just fricken
"like" would be gratifying
Whatever.....................................................................
Wesley
John.K1
Hi Wesley, others.
Quote...an experiment where two layers of foil are  connected together at one end and than connected in series with  wire (coil) that is not bifilar .
I believe this is a reference to one of your latest videos with coax cable , shorted at the end with "appropriate" resistor (value below the impedance of the coax),creating standing wave  - right?
I do play with capacitor coil on Ruslans devic too. But not the same way as you describe. More like to help to keep resonance  at any load. Watch this Russian video. For those who doesn't understand Russian, check his diagram - Inductor coil, 4m capacitor made of 2x Al tape (represented as two coils)  and collector coil. Check the scope when he put more load. No electronics needed.
https://www.youtube.com/watch?v=5Mi1nBNokrU&t=3s
regards,
AlienGrey
John.K1 if you have a coax cable and short the end once the wave (depending on its length gets to the 'short' will reflect back to the sauce, depending on F and the coax. it's recovering the exes energy that's the problem. you need some real test equipment to work it all out you cant just mess around and bingo it work on the living-room table.   ;D ;D ;D
The other thing is this you cant make or destroy energy, realy ?  for a start we live in a huge galaxy universe (a positively charged proton or have you noticed it's dark at night ? and the fact the universe is expanding and space is energy and not only that it's accelerating, have you ever thought we live in a black hole ?  so now your big bang is out the window.
Have you heard the latest America wants people in the south to scrap there solar panels for grid use and payments, and not only that it thinks it has the right to turf native Americans of their reservations in order to turn it all into an oil production site.
When are they starting on the pentagon lawn or the white house lawn ?
Grumage
Quote from: stivep on December 29, 2016, 10:08:16 PM
but just fricken
Wesley
Wesley, my friend..........
This one is " Just for you " !!   :)
Thanks for all you do, all the very best for the New year.
Kind regards, Graham.
John.K1
Quote from: AlienGrey on December 30, 2016, 07:37:21 AM
Alien, I have no F** idea what are you talking about :D  I do not mess with Coax  :D (yet)
:D  :D  :D
Regards,
