0 Members and 266 Guests are viewing this topic.
Jeg
Quote from: endlessoceans on December 31, 2016, 07:36:46 AM
1)  The direction is different because after the initial pulse there is no immediate decay in oscillations but rather expansions.  I have built a circuit of my own that is incredibly efficient (looks over efficient but I am reluctant to state such a thing at this point) and such a waveform I have seen over and over.  The initial problem was that it is so close to unity that the magnetic 'blowback' causes the entire circuit to choke on input and cease ringing.  The key is to bleed some of the energy off so that it can keep flowing and echoing smoothly
2)  Flow is simple.  Stop trying to send two rivers of water against each other in the same pipe.  All conventional circuits will never reach even close to unity.  When you wire it correctly, it is virtually room temperature superconductivity.  A good quality current reading instrument will actually show 4 times the AC than input DC and the DC itself will be massively high.  At first you will think the circuit is grossly inefficient but what has happened is that the current flow is so fast and so 'free' that it is circulating at massive speed through the oscillator and back through the source.   My batteries at the source will read higher than the resting voltage and when the circuit stops, voltage will not have depleted accordin to the current reading.  I have tested this with supercapacitors also rather than batteries and the results are the same.
3)  Coil is solid substrate and static.  Magnetic field is a dynamic gel that can be compressed and behave like a spring.  Key is to manipulate the field so as to not waste the fluid.
Hi endless ;)
That is very interesting, thanks for sharing.
Can you describe some more according to your experience? I can make the 'bell' but by switching on each cycle of the self resonant frequency. I haven't experienced yet any freely rising oscillation if its that of what you mean. In what order your bleeding resistor is? Is the thicker wire the better?
Thanks
Jeg
GeoFusion
 8)
A load test, also did a small recording on this one and beginning of scope shots that will be uploaded.
Cheerz
AlienGrey
endlessoceans
Quote from: Jeg on December 31, 2016, 09:20:48 AM
Hi endless ;)
Thanks
Jeg
Hi Jeg
I started years ago with the Joule thief (like most experimenters here) and then continued to build off that.  In the end the result was an oscillator that I have never seen similar anywhere online.  I know for certainty that I am on the right path and that is as close to 100% as you will ever see.  I have run tests with caps rather than batteries to remove all battery chemistry variables.  I can take 24v in one capacitor and fill another with no loss.  The circuit is a real bitter mistress though and for years I had terrible tuning problems until I figured things out.
In development you have to make sure there is NO HEAT anywhere.  Not on the switching transistor or in the battery/cap and wiring.  NO...there is no magical cold current but I know where all this misinformation comes from.  The best devices I have seen out there are CONVERSION devices (like the TPU).  They are NOT OU.  Its amazing how much energy is in a battery that LOOKS like OU when you run a system close to COP 1.
Jeg there is just so much Nonsense on this forum that I have only watched for years.  People like TinselKoala are CORRECT.  There is NO OVERUNITY.  What there is though is abundant FREE ENERGY around us.  By building a Oscillator that runs at COP 1 you can then use the source battery for incredibly long run times OR you can put up an antenna and easily draw about 100 watts between earth and sky.  NO this is not powerline energy.  I have conducted experiments in the outback miles from nowhere and you cant pull that much from radio transmissions either.
One thing I want to save people from wasting time here in is much of the Tesla quotes nonsense.  Tesla DID NOT have overunity.  People here that imply that or misquote him are LIARS.  Tesla used Grid power like everyone else.  Tesla was all about transmission of energy in a very efficient way.  YES he did harness 'cosmic' energy to run a little motor just as I have done from a antenna and he spoke of " ONE DAY future generations will use it" (perhaps).....but did he drive his pierce arrow around on it....NO NO NO.  Pierce Arrow was proof of principle for his Wardencliff wireless project.
With COP close to 1 you can charge batteries with incredible speed and make them last a long time.  (which is what bedini did)  Sad to say....BEDINI IS AND WAS A LIAR.  Him and all his cronies like Lindemann and Bearden, Murakami have never seen Overunity or men in black.  They sell books and vidoes and battery chargers.  I have nothing against people trying to make a dollar by selling things but what I DO have issue with is LIARS and misinfo because it wastes the time of genuine researchers.
If you want to really see some amazing things, ignore all the wives tales on this forum and go to the bench.  Build build build.
I may release some things in due course
endlessoceans
Hi endless ;)
Thanks
Jeg
Regarding your question about the thick wire.
All the principles of how this operates are set out in text books.  You will require thick wire AND thin wire.  Each serves their purpose.  Some components of the oscillator I have built are not freely published in textbooks.  This world and its economics wants things to stay inefficient.  Its like the car industry.  Why make only small changes to a new model each year??  Because that way they have a new product to sell each year...   Basic and yet somehow people fall for it.  So no they do not want to give us very efficient perfect devices now or a phone that runs for 40 days without a recharge otherwise they have no phone to sell next year.
I am sick of it.  So....the answer is educate yourself and build.  enpower yourself.
After years of reading literally hundreds of patents and viewing thousands.....you see it all.  Man some of the inventions and technology out there that guys built is beautiful.  Some of it was for devices that are better than what we have today and they were invented 70 years ago!!  (Like battery technology).  Tesla was way ahead of his time and we are still waiting to see the fruition of his wireless transmission tech.  I repeat.....it is NOT OU but it would be way better than the hard wired systems we have today.
