0 Members and 245 Guests are viewing this topic.
jbignes5
 Now lets discuss your knowledge of Tesla. You need to research everything and I mean everything he wrote and that includes everything written about him with his words in it.
Tesla was very aware of the medium and what happens when you condense the medium or cause a discharge across space. He knew before anyone else that the system was electric in nature. He knew about electric phenomena called a plasma discharge or lightning. He knew where the plasma came from that he was condensing and how to take advantage of it in his later experiments. It wasn't OU in the sense that it was from the environment but in essence was free for us to extract it.
If you are gonna talk about Tesla then you have to study EVERYTHING that was recorded about him.
The Pierce arrow experiment happened in 1931 or 32. Thats a fact. By then Warden Cliff was over and for a good amount of time. His experiment had nothing to do with the transmission of energy in the sense of sending it and receiving it. It was simply creating an imbalance in the ambient medium and harnessing the flow between that imbalance just like in his greatest example of the Niagara Falls experiment.
Tell me what you think is in between all matter? What allows the transfer of energy like in the example of induction? Why does this also happen out in outer space in a vacuum of that space? How does a vacuum tube work exactly? What conducts energy through the vacuum tube?
My answer is a low level plasma that is all around us and comes from the very 200 billion volt Sun we take for granted every second of every day. Plasma is what allows induction. Condensed Plasma is the reason for the electric and subsequent magnetic field.
His tower was a big ruse. From the point of view of the transmission part. He told Morgan that he could transmit signals to keep him in the game and allow him to build the tower. He admits this himself when Morgan pulled the financing after Tesla admitting he wanted to use the tower to transmit energy as well. The transmission of the energy was to be facilitated by the Earth itself. Now lets get to the energy itself and how he did that to transmit it. He knew full well about plasma. When he finally discovered that the plasma was already flowing all around us he figured out a way to condense it above his tower and use a blocking oscillator to modulate it's natural will to flow to the ground. The energy essentially came from this flow to ground and then he could transmit the energy through the same ground as an impulse that literally pumped the ground as in This example: www.tfcbooks.com/tesla/1919-05-00.htm ,  with figure 4 being the Earth example.
In this example: http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes04.htm
He lets out the idea of the transmission of energy via the ground. This is said in the explanation of the bifilar coil "In order to produce the greatest possible movement of electricity through a region of the earth in accordance with the plan involving use of a single terminal oscillator, as here experimented with, it is desirable to obtain in some way a large capacity on the free terminal. This is connected with difficulty as spheres get to be too large with moderate tensions and when the tensions go into the millions, streamers can not be easily overcome. The streamers involve loss of pressure just as leaks would on a water pipe which is closed at one end. Large capacity is obtainable in a number of ways of which some are:
1) a coil wound for maximum capacity (internal). The turns are so disposed that between the adjacent turns of layers there exists a great difference of potential, as much as the insulation can stand."
Reference: http://www.tfcbooks.com/tesla/1932-10-13.htm
Tesla was of the opinion that e=mc^2 was a total fabrication of the mind. This is because he knew the energy was all around matter and matter channels that energy focusing it like iron does with the magnetic field. The Aether was necessary to explain everything. Without it nothing can be unified in science. As evidenced by our current aberrations between the smallest and largest of scales in science. If we then put something there it all makes sense. The question is what can we put there. Well lets look at the clues. 200 billion volts would definitely have a plasma associated with it. We now know that huge plasma streams are connecting all gross matter in space. We are measuring this currently. Plasma can never be destroyed or created only condensed or dispersed. The ion description is a logical fallacy that is born in our minds because we couldn't detect the plasma in it's cold state. It is a transmitter after all. A highly dynamic one at that. A super fluid liquid crystal is the best description I could give.
AlienGrey
Ello, Ello, Ello, looks like Richards back, I bet Wesley will be pleased !!!  :o :o :o :o :o :o 8) 8) 8) :P :-[ :-* :'(
lost_bro
Quote from: jbignes5 on January 01, 2017, 12:14:45 PM
His tower was a big ruse. From the point of view of the transmission part. He told Morgan that he could transmit signals to keep him in the game and allow him to build the tower. He admits this himself when Morgan pulled the financing. The transmission of the energy was to be facilitated by the Earth itself. Now lets get to the energy itself and how he did that to transmit it. He knew full well about plasma. When he finally discovered that the plasma was already flowing all around us he figured out a way to condense it above his tower and use a blocking oscillator to modulate it's natural will to flow to the ground. The energy essentially came from this flow to ground and then he could transmit the energy through the same ground as an impulse that literally pumped the ground as in This example: http://www.tfcbooks.com/tesla/1919-05-00.htm  with figure 4 being the Earth example.
Good day jbignes5
Excellent posts likewise...............
"The universe is Grander than our widest views of it."  A. Einstein.
take care, peace
lost_bro
endlessoceans
Quote from: AlienGrey on January 01, 2017, 11:07:23 AM
So ocean is saying you can't get more out than with a man made device than in, ''RUBBISH''! for a start Nelson has already proved that you can and has made a profesin of the skill, and Tesla also said an iron crore based device is the path to look at, if your too lazy to experiment and just pick flies then you have no experience in what your talking about on on advising others and any one following that advice could be missing an opportunity!  I rest my case.  Dude!  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Rest your case???  LOL  Hilarious.  On what?  A youtube video displaying a light running for a limited time with no input or overall output measurements.
There is nothing special about what Nelson is doing.  He CLEARLY demonstrated exactly what I have replicated on the bench.....CONDENSING Voltage into useable Amperage.  It all looks amazing to the uninitiated and gullible but it is not OVERUNITY.  I don't expect you to understand this.  Go back to you Alien fantasies and youtube delusions.  NO wonder Tinsel Koala doesn't bother with this forum anymore.
endlessoceans
I'm not sure if you read my post properly....but yes of course plasma exists.  Why do you think I was differentiating between OVERUNITY and FREE ENERGY.   As I posted before very clearly to those that can read English, FREE ENERY is available all around us.  OVERUNITY is a wives tail.  Yes stick an antenna up and condense the voltage in the medium to useable amperage.  Knock yourself out.
However combining magical frequencies together in the hope of getting more out of a handful of inductors than what you originally put in.....no.  If there is more out than in, the energy is coming from somewhere whether it be  low level nuclear reaction or whatever.  THat is NOT overunity.  That is CONVERSION.
JBIGNESS there is nothing in Teslas writing I disagree with.....only the idiots who falsely interpret them to be something they are not.  Bifilar coils, high frequency oscillators, incredible capacitance.....yes it all makes for some VERY efficient circuitry where you can condense atmospheric HV down to useable current.   So what?  Go do it!  I already said you can easily pull around 100 watts of a antenna with the correct circuit.  Is this not drawing energy from the environment??  Is this not what Tesla spoke about??
Anyway there are a lot of talkers on this forum and I am already tired of it  Goodbye
