0 Members and 276 Guests are viewing this topic.
Dog-One
It's unfortunate AG people can't take simple measurements.  When he says "20 volts at 450 milliamps", it's really 20 volts at no milliamps and 450 milliamps at nearly no volts, because of the way he switches the meters.  From there, I'm not too inclined to take the rest of his demonstration very serious.  Who knows though, maybe building an Armstrong oscillator or two is worth our time.
Hoppy
Another demonstrator claiming OU with a naff setup, who does'nt understand basic principles.  :(
T-1000
Quote from: AlienGrey on January 05, 2017, 07:04:36 PM
And this one ?
https://www.youtube.com/watch?v=Adwf0NnQSyk
Not worth of wasting time...
How is your Kapanadze style replication going?
Also akula just had live streaming https://www.youtube.com/watch?v=OBpuiJHVqWg on yesterday and tried to show how lots of electrostatic charges can be generated using Tesla coil. And the polarity of charge was shown on Tesla radiant receiver style setup which was always positive no matter polarity in main circuit...
AlienGrey
Quote from: T-1000 on January 06, 2017, 05:14:51 AM
Interesting that you should ask, I Have been experimenting with the coil winding set and spacing's ect, I have been designing an, built a small tuning test set up rig, I hope to tune set up the windings and pre-tune them to the earths magnetic frequency , i will see how it goes but I have other things to do as well.
Yes an interesting video using polarized magnetic fields around the spark gas but as he was saying it's highly dangerous, have fun anyone who makes it :D
stivep
Quote from: Grumage on January 02, 2017, 12:16:01 PM
Dear Magpwr.
Was I on the right track ?
https://www.youtube.com/watch?v=uDofBGk4OCc
Graham.   :) ;)
Excellent.  it is directly related to
1.https://youtu.be/A7jbUA6_10c?t=1142
2.https://youtu.be/GTNjPXDsbjQ?t=157
not so directly  but related to
3.https://youtu.be/j-NLBSBRsBM?t=93
4.https://youtu.be/aJJW8qqa1O8?t=166 ( tariel's helper got shock from HV)
so we are talking about similarity  and properties  of capacitor that has been made  like coil , however  the from  the components of impedance
a- resistance
b. inductive reactance
c- capacitive reactance
the capacitive reactance depends from  size of inductor conductive surfaces.
Bottom line  is:
  Tariel  started from  spark gap
later on  told me that  spark is unstable and he needs to move to electronic HV impulse generator
here: https://youtu.be/IAPe3DiYt2o?t=579
please note that I was NOT sure at the time I have created this video -of- if what I say, is what was done by Tariel .( tariel's helper who assembled this  device  for the show)
SUMMARY :
I wanted to point here  at role of capacitive  reactance of conductor where we are getting:
a-  the  higher the capacitance  the higher is  voltage in the coil (coaxial  cable)
b- spark is a form  manifestation of high voltage  with no difference to the fact  , that we are dealing  with static  electricity  or just   capacitive reactive component of impedance.
c- spark and plasma  looks like it is not essential to have it  ,It could be  just HV impulse  as it shows at number of following  experiments after Tariel Kapanadze  ( Ruslan, Akula)
d- interesting is that when I have made video with Glenn Elmore E-line , similar to  Goubau  transmission line or Summerfield http://aeptransmission.com/ohio/Barnesville-Summerfield/
https://youtu.be/sweXFKSXMxo?t=37
I have noticed  certain similarity to SR ferrite kielbasa with wire in the middle,
Goubau is two cones creating  "sort of" invisible pipe  with center conductor in the middle but  this conductor has insulation  in the middle serving as a medium slowing speed of  electromagnetic wave
Glenn Elmore does not use insulated center wire but he uses set of  ring plates inside the cone ( dielectric)
In all of these transmission lines  frequency used is high 50MHZ and higher.
but if the distance between center wire and  outer wire is  big and there is ferrite pipe in the middle than  we are dealing with;
a- periodic mechanical change of domain polarity inside ferrite kielbasa pipe.
b- we still have  center wire like in coax  or like in transmission line.
c-- the frequency of square impulse is not so  low.
ad c:
if you take rectangular  wave form  -that one, is made out of  zillions  of transverse wave forms  of different  frequencies.often of very high frequencies.
Take  an example :Even if you interrupt regular DC circuit with the regular switch than  you have zillions of  transverse  wave forms  at rise-time and fall-time of that  impulse( the higher the voltage the more evident they are)  and every time you interrupt it with the switch  you have ionization of  air taking place.
You may say that with few volts  from DC battery there is no visible ionization taking place. However Tesla coil is sort of transforming  "voltage multiplier" the higher is voltage potential the lower would be the current but the more ionization would take place.
Tariel first  started build his devices based on   Spark gap  because spectrum of spark     has zillions of transverse  waveforms.
by that Tariel was never worry what is the single transverse component that is going to do the job in within spark spectrum frequencies. there was always one present  and ready for him to interact.
during spark generation when spark  gasp increases or conductivity of spark electrodes surface changes there is always any neighboring  frequency  in within the spectrum ready to interact
Than  I start to think......
What is  if any  the common link between:
1. spark
2. spark gap distance
3. spark generator  -( impulse generator) from water heater
4. square wave impulse and its  length
5. DC square wave rise and fall time(there are AC components)
6. Transmission line
7. SR middle center wire in pipe
8. coaxial cable
Wesley
