0 Members and 317 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on January 18, 2017, 08:11:35 AM
Watts that mean, Last year October he had a device in a PC power box, he took the lid off you could see a lot more, you can for get the battery theory, that's not it the magic is done in the way the coil is wound (it was part 5), that reminds me he said he was going to show us how to copy it !  8) 8) 8) ;D ;D ;D ;D
as if that was going to happen.
Alien,
If joule look it up on goggle, its a 3V lithium cell.  ;D
Meta
Gentlemen,
Do you see the HV black wire from the spark gap thru the transformer
Now the author complains he cannot get anything through that wire except HV electrons.
He has reached the plasma stage but cant step it down properly
Remember our 4 states of matter?
1D matter
2D liquid
3D gas
4D plasma
The author already reached 4D gravity where the plasma is undifferentiated/unpolarized and asymmetric. How do we transmit it?
Common new, black wire is not the way.
Try coax, with its shield so the center, contaminated copper wire holds the plasma in the middle of the wire.
Better still try Chris Sykes "burned wire" which is contaminated wire, proper for transmitting plasma from 4D to 3D using the Hole Theory, the theory that describes negative/virtual electrons, ie, electricity that moves opposite to normal electrons.
The author might use plain "burned wire" (wire containing holes) or he can pull out the new, center copper wire in a piece if coax and insert the burned wire into the coax and use the shielding to contain it even further.
The rule is,
New wire doesnt work for neg-electrons, 4D.
Contaminated wire works to transfer 4D to 3D.
Hoppy
Quote from: Meta on January 18, 2017, 12:30:16 PM
The reason he can't step it down properly is because of a drastic impedance mismatch!
AlienGrey
Quote from: Hoppy on January 18, 2017, 10:19:04 AM
Alien,
lithium,  No i was referring to the bad hand wroter! Well beam me up scotty. I'm surprised T1000 missed the note in section 7 of the video comment, you too Hoppy, he uses a Tesla TX coil of camera to obtain his affect !
Great he has removed that statement now ! so be warned.
HA HA!   www.youtube.com/watch?v=QGo0Dd663ow&spfreload=10
zalmoxis
