0 Members and 123 Guests are viewing this topic.
stivep
 here is some hints about  author possible location
and language:
https://www.youtube.com/watch?v=Hdc9WPM2suA very first 2 seconds of video
Wesley
AlienGrey
Quote from: stivep on January 18, 2017, 05:48:01 PM
and language:
Wesley
Top comments
tol musta na? that here in the Philippines?
Reply
he keeps changing stuff ;)  it's  just a grenade coil wound over the top of an eht coil like original. Thing is does it have ferrite rings in the core the original did.
zalmoxis
I don't want to change the current subject about what you guys are talking about. I have a big issue with the tesla coil for the Alexeew Sergey schematic .. he says in his schematic http://overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/161979/image// what the length of the tesla wire should be 4.5 meters, a wire of 1,75 square mm, this means a wire of 1,5 millimeters in diameter. I've ordered a roll of 15 meters of wire  :-\  :o . I guess that the length of the wire should be much larger than 4.5 meters because with what he says to use i only will get around 30 rounds for the coil ... i need some help here .. GeoFusion ? Acca?! T-1000 ?  anyone ?
GeoFusion
Quote from: zalmoxis on January 19, 2017, 10:41:49 AM
Hi Zalmoxis,
I have seen his diagram and compared it with pictures of his setup
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/159455/image//
Look at the secondary turns, that is a much thinner gauge and for what goes on Ferrite choke is
thicker as we can see.
to compare to mines
1.75 square mm is quite thick for a secondary, It will introduce alot of Ionisation and amps in arcs.
That I have done with 1.5 square mm with almost 3 meter tall tesla secondary SG neon sign trafo.
produces wild static all around , alot of corona and a heavy smell of Ozone.
on bench conversion device my kacher secondary I have used 0.4 - 0.5 square mm  ( 24AWG or was it  26AWG )
Hoppy
Quote from: GeoFusion on January 19, 2017, 12:03:40 PM
Hi Zalmoxis,
How can we be sure that the circuit diagram relates to the picture? Maybe he has another perhaps improved device that does correspond to the diagram.
