0 Members and 137 Guests are viewing this topic.
GeoFusion
Quote from: Hoppy on January 19, 2017, 12:18:19 PM
How can we be sure that the circuit diagram relates to the picture? Maybe he has another perhaps improved device that does correspond to the diagram.
Hi Hoppy,
Yes, that is one of the possibilities
zalmoxis
The Image relates to my schematic , the tesla secondary could be 1.5 and the wire that goes to the ferrite could be >2 mm diameter.
The most important thing is the wire length or the number or turns .. the diameter of the wire if it is bigger is as Geo is saying that it will push more amps
Ok I'VE FIND IT!
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/159453/image//
The tesla secondary is 0.8mm2 and 19 meters just like the inductor is , output coil 38m, inductor 19m  with 2.5mm2
Also the winding on the tesla primary and secondary is identical to the photo GeoFusion has posted, are CW both of them .. ok, i have to buy new wire .. hhahaha .. see you in one more month :))
GeoFusion
Quote from: zalmoxis on January 19, 2017, 12:43:51 PM
Ok I'VE FIND IT!
Yes, I think it's that, 19Meters 0.8mm2 for secondary tesla.
38Grenade.
19M inductor, 1/2 lenght from grenade.
Btw in diagram he should have put the Primary of tesla kacher coil the opposite direction.
Primary CCW and secondary stays CW.
There was one time I saw a Tesla Coil function on CW to CW set.
But not sure.
Importance is always here with the match of wire lenght to match Frequency when transmitted and pulsed.
Soon enough I will try out this way of hooking up the Coils.
Akula's original setup is also based on how Sergey did the connections. Ruslan also repeated this and succeeded.
I am still experimenting with Ruslan's No1 Setup. ( Series the 28T+ with grenade with Blocking Diodes.)
Utopia Now
Hallo Zalmoxis,
in your schematic that you posted january 12   i see the Grenade Coil is all wound in 1 direction.   I think  the trick is to wind it half length, 19m cw and other half length 19m  ccw. Or maybe first half ccw and than the second half cw
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg498262/#msg498262
Here  in this document  are some arguments and info about  why maybe CW CCW  ... than they work as "partnered output coils"
You can klick on links and video fragments ... https://prezi.com/dp7j0ydwqmu-/don-smith-bucking-coil/
But you can test is yourself  ... ...  I am not sure if the picture from Alexeew Sergey scopeshot is from the coil with or without the capacitors from the schematic connected ..
Yess I still have to learn a lot.
On the schematic from Alexeew Sergey  he has round curled arrows that show the direction of winding from the Grenade Coil i think  ... and also the dots indicate the winding direction .
Good Luck
Utopia Now
Meta
Quote from: Hoppy on January 18, 2017, 12:44:22 PM
The reason he can't step it down properly is because of a drastic impedance mismatch!
Can he not discharge the plasma into the load, in nano-seconds, so avoiding the impedance mismatch, then pick up another chunk of plasma and quickly discharge that also, by re-gauging?
