0 Members and 334 Guests are viewing this topic.
verpies
Quote from: Meta on January 19, 2017, 11:36:24 PM
Can he not discharge the plasma into the load, ....
That question is not even wrong
AlienGrey
this is the grenade coil note it is in 14 sections, two are 4 sections long, two are 2 sections long an two others are only 1 section long. Notice the importance here relating to the Tesla winding. It is important to bear this relationship in mind. Re Stalker lecture. Also note the tuning capacitors. one should also pay attention to the mathematical significance of the mathematical significance that is going on here.
On the other hand, as a skeptic what if my ar(es) was my elbow!
AlienGrey
Quote from: zalmoxis on January 19, 2017, 10:41:49 AM
I don't want to change the current subject about what you guys are talking about. I have a big issue with the tesla coil for the Alexeew Sergey schematic .. he says in his schematic http://overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/161979/image// what the length of the tesla wire should be 4.5 meters, a wire of 1,75 square mm, this means a wire of 1,5 millimeters in diameter. I've ordered a roll of 15 meters of wire  :-\  :o . I guess that the length of the wire should be much larger than 4.5 meters because with what he says to use i only will get around 30 rounds for the coil ... i need some help here .. GeoFusion ? Acca?! T-1000 ?  anyone ?
it's the length of the wire not the no of winds here (wave length) to the frequency.
zalmoxis
@AlienGrey yes we have figured out the wire lengths and the turns directions .. if it will not work i'll have to try different setups
@Utopia Now - i have just a normal multi meter, tomorrow I will poweup the entire PCB i will try to use soundcard as an oscilloscope to see the output from the PUSH PULL driver .. if it's over 20Khz .. then i'm lost with the tuning ... i will "I will try to learn to drive blindfolded" haha  ;D ;D
