0 Members and 66 Guests are viewing this topic.
stivep
This forum is not a playground for some Kids. Show your level   and your contribution to this forum.I was told that there are some new individual/s using improper language and improper forms of  expression/ descriptors  directed personally to  to Stefan  and/or to some other   members of this forum.
Whenever I have made that  statement in the past,  the person who was causing  disturbance was deleted  including all of his posts.
So this is the warning !!!!!!!
Next  is only OUT !!!!
without any prior
GET OUT!!!!!
I do not care who you are
Please think twice before you place your comment.
Wesley
bitbo
Hi Itsu !
I continued my work on the kapanadze coil recently:
this one here: https://www.youtube.com/watch?v=j3b7jVnQYKU
I have good results using 1500v Spikes  (appr. 85% efficiency)
My problem is that i need way to much energy to generate this spike.
I came across your Nanopulser and would give that a try on my coil.
How miuch input power consumes your Nanopulser generating this 1500v pulse ?
(i need apprx. 15 Watts)
If yours is better, may i lean or buy yours.
(i live in germany close to the netherland border - maybe we could meet...)
Thanks for a short reply
bitbo
Remark related to winding direction of grenade:
I do get close to no output, if i exchange poles on my bifilar input coil
(both "positive" poles must be either on left or right side - like the legendary tesla flat coil)
magpwr
Quote from: bitbo on January 21, 2017, 05:17:42 AM
Hi Itsu !
bitbo
hi bitbo,
I have got high efficiency broad frequency 1.1kv Nanosecond generator (~8ns) which can handle up to <2Mhz in my youtube channel:sanjev21
1.1KV High frequency Nanosecond generato
r
http://www.youtube.com/watch?v=dyR4GVM99JI
Parts obtained from digikey,mouser and ebay for the Single Avanlche pulse 3Joule 1kv Mosfet  APT10035LLL.
Parts for this "basic nanosecond pulse project"
already cost around 100usd.The high Q /7KV smd capacitor alone already cost around 32usd each.
The air core smd inductor needs to be higher than 1.5Amps ...2Amps rated. :D :D :D
Do read the youtube expanded description and play video in hd for the schematic.
As mentioned the generator merely need around 47volts dc (XL6009 modified voltage boost circuit)to produce 1.1kvpp.This is little more than 20times the input voltage. :)
The hardest part to obtain is the Russian diode KD226D (Connect 5 diode  in parallel configuration)which i got it from lithuania.
Whatever i post in my channel can be replicated provided if you got the money to spent on parts and if you are well verse in Electronics.My parts don't come from dumpster. :D
I got advance 6kv nanosecond generator but it's not for public demo. :)
itsu
Hi Itsu !
bitbo
Hi Bitbo,
looking at your video (nice job by the way), i notice its almost 3 years old (3 May 2014) and allthough the big coil looks like a Ruslan type coil it seems to be 6 separate coils.
The diagram in the comments of this video confirms this, so it more or less works, like mentioned by someone in the comment, as a transformer.
You input 30V (0.5A) square wave (65-21Khz?) on L5 (2x 48 turns) and show on the scope a 1500Vpp ringing signal which i am not sure where it comes from.
L1 and L2 have 256 turns, so probably its from one of them.
This 1500Vpp (bipolar) ringing signal is a normal reaction of your transformer on your square wave input signal.
I am not sure where you would fit in the nano-pulse in this setup.
The nano-pulser provides an unipolar pulse of about 1.5Kv @ 12ns over 50 Ohm.
So you would probably need to wind a coax cable somewhere in/around your 6 coils and pulse that in the hope it would "disrupt" some of the signals in the 6 coils.
But as your setup is way different then Ruslan, i fail to see the big idea behind it.
Anyway, i have no idea how much input my nano-pulser draws, as this is highly dependant of the pulse repetition frequency.
Below 10Khz it draws low amps (@ 24V), but this increases fast when going to 15 or 24Khz.
Presently my nano-pulser is out (blown IGBT) so i cannot check.
I will try to repair it using a Cree MOSFET and do some measurements later this week.
Maybe you can explain how you would "use" the "unipolar pulse of about 1.5Kv @ 12ns over 50 Ohm" in your present setup, thanks.
By the way, did you use a special ground connection in your setup  (other then the ground connections from your FG / scope / PS)?
Regards itsu
Don1
Quote from: Dave45 on July 16, 2014, 07:27:52 PM
Nick this is an easier circuit to lay out, mine is built like this with no problems.
I used irfp460's
Hello, I was wondering if those 4 same looking diodes were all UF4007 Diodes? Thank you for the reply in advance
