0 Members and 40 Guests are viewing this topic.
verpies
I don't know. The last time that happened when I was thinking about the Steorn Orbo motor, but somebody discouraged me from it.  See here.
NickZ
  Although people have been spinning magnets around coils for years, or the other way around, I have not seen it done for free, and obtain OU.  Capacitors, or no capacitors. Ismael has been working on this for several years, and...I do hope that he gets it, but Akula has already got it, at least to some degree. So, I'm still going to play that hand. No noisy spinning thingy.
  Romanov may have gotten it too, but is just showing a diagram, and using over 3 amps of input to light a bulb. So...I believe what I see, and leave the rest to my detective friends.  Time will tell, it most always does.
Hoppy
Quote from: NickZ on May 25, 2013, 08:14:38 PM
I've been spinning magnets around coils for years and the shorting of coils is nothing new as has been pointed out. Many Bedini fanatics, including myself have experimented with coil shorting. Grum conducted an interesting experiment with coil shorting and reported loading of the rotor. The bottom line is that generator coil shorting does impose a load on the rotor and this affects the running performance of the motor. If a Bedini SG energiser (motor / generator) is used, fitted with an additional generator coil with timed shorting by mechanical switch or semiconductor, it will be seen that whenever energy is collected into a storage capacitor on each rotor magnet pass (connected as shown by Verpies in his posted schematic), rotor speed will reduce. It can be difficult to detect this speed decrease if the rotor is heavy and spinning fast, as it acts as a flywheel that has a considerable amount of energy stored in its mass. The speed of the rotor affects any electrical output that is being taken directly off the motor coil in the form of coil discharge for the purpose of charging a secondary battery. Measuring the energy stored in the cap as a percentage of the energy removed from the rotor is clearly not an easy exercise but the fact that there is a transfer of energy, strongly suggests that the energy stored in the cap is not free. The SG will always seek an equilibrium when running and the interference of any one of its variables will affect all the others.
My belief is that Alvaro has seen a real device performance increase due to the conditioning of his battery bank through 'spike' desulfation. I wager that he will not be able to replace his batteries with capacitors and see the same performance - time will tell.
T-1000
Quote from: Hoppy on May 26, 2013, 05:07:22 AM
Mechanical relay shorts for too long. Also you can easily repeat that with with 10+ MOSFETs in paralel on mechanics or even better - on transformer and see results. Maybe that will throw away not needed speculation.. ;)
Hoppy
Quote from: T-1000 on May 26, 2013, 06:51:15 AM
Not if the rotor speed and resulting period of waveform is matched to speed of mechanical contact for experimental evaluation purposes. It looks like we will just have to agree to disagree.
What is the shorting period as a percentage of the waveform period for good performance when using mosfet switching?
