0 Members and 73 Guests are viewing this topic.
Bewusstindiezukunft
Видео Наиля по БТГ - NNaill BTG Video -  Bratan Ivanon channel  :D
Watch
https://www.youtube.com/watch?v=xdg1IbWIkZM
https://www.youtube.com/watch?v=k0rp1Sjkt2M
https://www.youtube.com/watch?v=BWZTxeNRLSI
https://www.youtube.com/watch?v=hcdqVTOB9FU
https://www.youtube.com/watch?v=Bb4QPXp9iAc
BTG = Безтопливный генератор = Free Energy Fueless Genarator = Kapanadze Generator
Correct schematics and Signal Oscillograms in NNaill.rar Archive. Take it to winchester disk and share for FREE. All nee Free Energy not only 1 man. !!
And remember Bewusstindiezukunft
N20Wolf
zalmoxis - Hello! You picked the capacitors at that location? Where there are stars must have to choose capacitors on the maximum amplitude***
attached torrent file everything Sergey Alekseev files https://yadi.sk/d/idQsCZ1r3EGcRJ
AlienGrey
Err it's a torrent file, we cant access that type of file have you got a program or a way of unpacking those files ? so we can all see them ?
saturnio
Quote from: AlienGrey on February 19, 2017, 07:56:18 PM
AlienGrey, you can use uTorrent program, downlad and install it. Then download N20Wolf file from link, add it to the installed program and files will be downloaded in a few days
http://www.utorrent.com
zalmoxis
Quote from: N20Wolf on February 19, 2017, 01:11:54 PM
N20Wolf ... i've tested different capacitors values.
With a total capacitor value of 1.13uF (330+330+470) i get the maximum grenade output with the push-pull frequency is 17-18kHz. Lights a bulb with a power of 75W at full brightness with 220-240Volt output. The inductor is winded in 2 layers in tesla-bifilar 9.5m of length in the counter direction of the L1 and L2 of the grenade.
I can get it resonate also at 23.3 - 23.8kHz with 660nF with the highest bulb brightness .. but the bulb is not lit at the same value as using lower frequency and 1.13uF
I use 9.5m instead of 19m because i can't fit 19m of wire on only 3 layers  ???
So correct me if i'm wrong .. how should i tune it:
#1 putting on the caps and tuning the frequency for the maximum output
or
#2 setting the fixed frequency of 23.5kHz (or other specific value) and work with the caps to get an maximum output ?
What do you think that *330pF cap is doing .. where and what should I monitor on the oscilloscope.
What role would play the grenade caps? Increasing the value .. the output power dropt. I use now 165nF (2x330nF in series)
Is there an exact push-pull frequency i have to achieve or just to push as much amps as possible?
