0 Members and 348 Guests are viewing this topic.
wattsup
@stivep
Thank you so much for the patience required to do this video. Just a work of benedictine and objective precision.
Your last statements regarding the theory of operation. Yes, although it is so tantalizing to go down that route
again, I am still very leery of these devices. So what is the point of making a theory that may wind up reinforcing a
potential fakery?
I was going to post a theory but prefer to ask simple questions instead and save the theorizing for another day.
In the video we see one Tesla Coil (TC) and one receiver coil. But if the receiver coil is a receiver coil, why not put
25 receiver coils? If the impulse is 360 degrees off the TC secondary or if not how can it be directional to only
one? See. Questions are fun.
The 2000 watts was what I said at the same time you said it so the count is good for me. So let's say 9 amps. The
receiver cannot do that. But it could produce enough to keep a low volts higher amps drive end going on the TC
Primary. That is the loop. He then takes the two blue coils wound over the TC Secondary and produces a floating
potential difference as output so who cares about ground at this point the output is floating or isolated.
The ground does what? The receiver produces a good strong positive pulse on the primary. Then the ground
provides a same strong primary pulse as the rebias. So he is producing positive pulse from the TC output. Feeds a
positive pulse to the receiver that feeds that positive pulse at lower volts higher amps to the TC primary again and
the ground provides the negative rebias. I could get into atomic nature or the why of this but prefer to just wait.
So you use a floating scope on the output, then put a scope on the normal house AC, if they are not in phase, I
would be happy. If they are, then I would have harsher questions.
wattsup
Jeg
Quote from: stivep on March 01, 2017, 06:56:03 PM
...and plenty of commercial grade software where just one of them cost more than  Russian Nurse makes per year.
Hi Wesley. Thanks a lot for your translation once again.
Just only to comment that Russian nurses look quite more efficient than most of the commercial software out there. ;D
Hoppy
Wesley,
This is all getting silly. Just ask the guy to show a high res shots of the so-called earth wire connections and all will be revealled.
T-1000
Quote from: stivep on March 01, 2017, 04:08:52 PM
T1000  this is what I got from Polish FE guy.
Wesley
Hi Wesley,
The document is describing creation of standing waves which transform to explosive longitudinal waves and are creating output frequency by doing that. Yet it is just one of theories how the power is being amplified. Without working setup this cannot be proven as correct theory..
Cheers!
stivep
http://www.ebay.co.uk/itm/FREE-ENERGY-GENERATOR-ZERO-POINT-ENERGY-7-3Kw-220V-/132106746213?hash=item1ec22cf965:g:9DQAAOSwax5YsGWe
Details about   FREE ENERGY GENERATOR, ZERO POINT ENERGY 7.3Kw 220V
Seller information   since_0001 (393)   100% Positive Feedback
Item specifics Condition:
New: A brand-new, unused, unopened and undamaged item in original retail packaging (where packaging is
... Read more about the condition:
The world's first commercially available free energy generator.
Delivers an output of 7350w 220V without using any fuel for its work.
Typically it uses its own energy to work by itself.
This is a completely new approach to the way electricity is produced.
It is designed to work in private homes and cottages or small workshops or independent objects.
It is designed to work constantly 24/7, but it can be manually switched off and on again, as it has a spare gel battery 48V / 36Ah.
For more info, please contact me.
Do not think that I sale anything :) This is just copy from Ebay.
but guy has 100% positive rate
and he sold  393 different pieces
Wesley
