0 Members and 347 Guests are viewing this topic.
NickZ
   Happy.
  It's going slow,  but steady.  I'm using mostly all recycled components.
Hoppy
Quote from: NickZ on March 02, 2017, 09:02:33 AM
   Happy.
Yes, take it steady. Check & double check connections are correct. If possible use an IC holder / socket for your TL494 as changing a chip, if needed, with the type of board you are using is messy!
NickZ
   Yes, the socket IC holder would really help, I'll install it if I need to replace the TL 494 chip.
   I'm nearly ready to add the fet drivers, and snubbers, next. All to be installed on that single PCB. No long connection wires.
Hoppy
Quote from: NickZ on March 02, 2017, 10:07:20 AM
Nick,
Tip: Test each circuit element as you proceed. Don't just connect everything together and wonder why it doesn't work or a component smokes! Firstly test that the voltage regulator(s) is functioning correctly before connecting power to the TL494. With the TL494 in circuit, test the frequency and duty controls by scoping the outputs for the correct waveforms. Then connect and test the FET drivers and scope for correct waveforms before connecting the FET's and snubbers to supply rail and load.
