0 Members and 285 Guests are viewing this topic.
AlienGrey
Quote from: Acca on March 02, 2017, 08:18:18 PM
no such thing as free energy. or free lunch.
Any one see that plastic tube in the corner ? can you see the top of it? so how do you know his earth cable isn't 'power' ?
No such thing as a free lunch ? are you so sure ? it depends on how high you are up the ladder and who you are ! and what you know, and if your an empire builder or what little syndicate you have got running.
So if you think there is no such thing as tuning into the system as it were, well I don't ! let's put it like this their is the 'yin and the yang' if some thing 'does' exists then if that person who offers it to you is a bit of a Charlatan and you play along and buy it then they have their free lunch ! ;)
If some one has free energy, it's as Wesley has said give your knowledge away (all the tricks and secrets) let any one build it who wants to, that way you would be free to do as you wish in your own business, unless you want the world banging at your back door.
stivep
Quote from: Zephir on March 05, 2017, 09:41:20 AM
1,Quote from: Wesley/stivep>Overunity does not exists and never existed in world of energy.
There is no such thing as free lunch , but there is lunch someone pays for.
And in our case this somebody is nature. So the reason I'm with you here and I make my videos is that I know for sure that energy conversion where we do not pay for original energy is a fact
don't understand - how such a situation would differ from overunity as such, i.e. in classical sense?
2. Quote
It is yet to be found it this is fraud or not. ..ground is not uniform and two grounds ( ground connections) in the given distance behaves like impedance with its own
But it's evident for me, we still have no exact scheme of Maxim Aliev's device - so how can you be sure, there really exist two grounds?
Ad2: I think Maxim Aliev's device is not yet  worth  our attention to the degree of deep analysis.
ad1.
In a financial world: You got $100 more just because stack went up or your house sold for more and that gives you money to buy more energy or to buy again.
That is why unity and overunity is mostly future of a bank who never lost and always invests less and gets more.
In world of physics:
when you start from one energy level you can only lose,  never gain. and mostly the "refueling"- regaining energy  cost you money.
Loss is inevitable  money can not make person to never die.
constant  unity is another name for perpetual motion: The  hypothetical  continuous  operation  of  an  isolated  mechanical  device  or  other  closed  system  without  a  sustaining  energy  source
1.
Also  called: perpetual motion of the first kind motion  of  a  hypothetical  mechanism  that  continues  indefinitely  without  any  external  source  of  energy.  It  is  impossible  in  practice  because  of  friction  2. Also  called: perpetual motion of the second kind motion  of  a  hypothetical  mechanism  that  derives  its  energy  from  a  source  at  a  lower  temperature.  It  is  impossible  in  practice  because  of  the  second  law  of  thermodynamics
overunity
is unity  plus additive energy :
means the device uses already more energy that it has in the system and produce excess energy. Good for the bank and financial operation but not in physics. ( that is why we have monetary inflation)
"Free lunch" - Prescriptive Illusion
Theoretically-we have 16 century man watching modern combustion engine for 10 hours and he might see it as both perpetual motion machine and overunity if load is connected to make an external work.
He than went to restaurant and as very famous noble respectable  individual ( Leonardo Davinci )  he is told "your money is not good here everything you get is free ".
Energy transformation:
( conversion)
QuoteEnergy transformation, also termed energy conversion, is the process of changing energy from one of its forms into another. In physics, energy is a quantity that provides the capacity to perform many actions—some as simple as lifting or warming an object. In addition to being convertible, energy is transferable to a different location or object, but it cannot be created or destroyed.
Our" overunity "concept:
is practically  process of providing physical device that uses:
1- energy to make work
2-by means of energy conversion  is providing power to  itself  and providing power  power  to additional loads in while maintaining its own integrity and sustainability.
3- We do not have to pay for any of that despite the initial cost of the device /system
that works:-Valve on the pipe with water requires very little of hand pressure, depending on valve type, construction, area and spring characteristic and orientation in piping system,
Now the water from a River does the work.( however  gravity rules apply)
- Creating Pressure in the Tank Using traditional mouth siphoning It worked in aqueducts in Roman Empire.  ( however  gravity rules apply)
- Electrostatic charge, wind, solar,  tectonic, thermal,  and so on. if utilized it  does  useful work for us.
The same way we sip  fuel from gas tank with one impulse only  we can couple ( open valve) to   Schumann resonances- telluric current-nuclear bonds energy, NMR, mechanical shaking of ferrite molecules  in fast switching domains where delay  of switching is causing electrical response in  circuit .
All of it is more o less sense or nonsense to a scientist.
but to be clear :
If electrostatic charge exists due to i.e.  wind  sweeping air particles around. and we  utilize this charge. Immediately these air particles are   charged again "at no time"
Density of charge  and area of charge delivers constant current flow.All you need is the right device  to use it.
Wesley
Zephir
What looks strange for me is the lack of 220 AC converter at the circuit. You could power the light bulbs directly from HF output of tesla coil, but not the mobile charger or even computer monitor. These devices are quite sensitive to the grid frequency and voltage.
Dog-One
Quote from: stivep
In other words, overunity clearly does exist; all that is required to see it in daily operation is to exchange the terms
money & work.
I work for money, which is actually useless paper (not even that now with modern digital banking systems).  This money
has zero intrinsic value and the issuers of it create it freely.  BTW, if I create money freely, I go to prison for the rest of
my life--seems like a double standard doesn't it.   >:(   So the system has me working for worthless money; without this
worthless money, I cease to exist.  I perform work or labor in exchange for this worthless money.  I am the source of
overunity.  See how that works?
Now you see, money and work actually are one and the same thing.  People who do work are the free energy for those
that control the system.  People that have a lot of money typically begin to trade some of this wealth for power.  Why
use the word power?  Because that is exactly what it is--work performed per time interval.  It takes money to make
money.  It takes power to make more power.  See how simple it is?
Is it any wonder why I would be imprisoned for creating money?  Because by doing so, I have access to overunity.
I could use that money to get others to do work at nearly zero cost.  I could harvest energy just by controlling a
scheme.
It doesn't take a person of high intelligence to realize what is going here.  The tribe of creatures that have set this
system up know full well overunity exists.  It's their system and they will ensure it does not get derailed at any cost.
I will go so far to say they would destroy everything on planet earth before letting their system be taken down.  All
it would take is for one electrical device to be replicated and massively spread that emulates the very system they
have created.  That would be game over.  Their system, their wealth and their power would be relegated over night.
Money would become a term of ancient history once energy harvesting machines took its place.
It's never going to happen is it Wesley.  Not in our lifetime.
Zephir
The free energy is only one part of equation: once it will become reality, the people will start to fight for free resources and free space. These things cannot be created so easily even with unlimited amount of free energy.
