0 Members and 348 Guests are viewing this topic.
Zephir
The L2 coil at the above scheme must be bifilar - or it would drain the power from primary circuit like every winding of transformer. The requirement of resonance at the output could be fulfilled automatically by utilizing it as a feedback winding of oscillator (kacher, Joule thief). Otherwise the input frequency must be tuned for every load individually, which is impractical. Another option is to draw the load with another bifilar, which shouldn't affect the resonance of secondary circuit very much. This option is used in most of Kapagen replications, which therefore have two secondary coils. The overunity results from mutual interaction of high energy density fields: electrostatical and electromagnetical one, which form an anapole field with broken SO(2) symmetry. In such a case the magnetic field must change faster than the electrostatic wave can propagate along surface of winding (evanescent wave along air core high voltage coils) or vice-versa (ferrite core coils). As an added value the device should exhibit reactionless thrust, if working properly (compare for example Stoyan Sarge or Woodward effects).
Zephir
The anapole circuits seem to violate laws of physics, but IMO their overunity results just from fact, that the speed of light is invariant and that the magnetic field tends to follow electric field propagation in symmetric way as Maxwell predicted. But the permeability of ferrites or permeability of capacitors depends on the intensity of magnetic or electrostatic fields too. The higher are these values, the slower the electromagnetic wave propagates. For example if you place the piece of iron into intensive magnetic field, it will get saturated with it and it will behave like the copper with respect to high frequency field. It wouldn't focus and slow down the EM wave anymore. The speed of EM wave can be therefore modulated in certain range with gradient of intensity of electric or magnetic fields, which can propagate independently. At the case of sufficiently intensive and fast changing fields we can achieve the situation, when at some place of circuit the electrostatic or electromagnetic component of EM wave gets delayed after its dual component because the gradient of permeability or permitivity travels faster than the EM wave itself. This just happens within resonance circuits, where not only transverse but also scalar (longitudinal) waves of vacuum bounce back and forth. The vacuum literally "tries" to balance the resulting asymmetry between magnetic and electric waves with superluminal scalar wave, which speed-up the EM wave and this additional scalar (2-spin) component could be drained from circuit with bifilar coil.
From general geometric perspective of dense aether model, the overunity is quite opposite (negentropic) effect to heat dissipation in electric circuits. The heat dissipation arises from increasing dimensionality during charge propagation - the electrons collide and bounce mutually - so that the portion of energy spreads into outside and it gets wasted. If the vacuum would be fully flat homogeneous material, then the opposite situation couldn't happen. But because the vacuum it's actually filled with density fluctuations, the charge never propagates along fully straight path even at absolute zero temperature. So we can achieve the opposite situation, once we make the propagation of charge more straightforward than these fluctuations normally allow. We can literally achieve the undercooling of charge propagation bellow the thermodynamic temperature of environment. BTW the recent preparation of time crystals has been achieved with similar principle and the time crystals can also serve as an example of perpetuum mobile.
Therefore the overunity is enabled by lowering the dimensionality for EM field propagation within special materials and systems. The electrons are forced to move along narrow channels (superconductors, topological insulators, capacitor plates) or flat circles (ferromagnets) inside these materials. This leads into situation, when in certain range of electric/magnetic field intensity the permittivity or permeability of vacuum DECREASES with intensity of the field instead of increase, because the increasing field intensity breaks the barriers for electron motion and charge propagation. Normally the increasing of energy density would lead into increasing of vacuum density proportionally because of E=mc2 equivalence - the ferrites, capacitors and superconductors are therefore anomalous systems from this perspective.
endlessoceans
Quote from: PolaczekCebulaczek on March 05, 2017, 08:55:39 PM
Steal from SWER? how?
Very simple but if you are asking this question you are LONG way behind Tesla research 120 years ago.
It is all in front of you with a battery or hot wire.  How does it work?  Potential differences.
PolaczekCebulaczek
Quote from: endlessoceans on March 06, 2017, 07:49:33 PM
yeah, actually I have a few ideas... and i think I would be able to replicate a "fake video of FE from water pipe running a tv"
