0 Members and 347 Guests are viewing this topic.
magpwr
hi everyone,
If i guess correctly nobody really took the drawing seriously as attached by someone few weeks back whom "stivep" considered as newbie and maybe a distractor or disinfo agent as what
Russians forum say.
If you are able to recall the below 2 videos which i have linked and observe the additional capacitors from 25..28 turns and compare with the attachment.
Try swapping the 25 or 28pin like the attached **********1.jpg.
I was very surprised without kacher turned on for the first time i am able to get the bi-directional Leds connected in parallel on "1 turn" on blue toroid to be lit(My simple version of current detector to Earth).
This indicated there is high voltage present at mere 12volts battery as power source without kacher switched on and this is good news.
Recall in one of the videos there is blue glow on bulbs.Think about that.
Probe must not be connected at any point but merely place just beside say 28 turns wire.You will notice there is higher frequency present with around 500ns spike at around 15volts."Remember Probe not connected".For my case.
Not forgetting the 2 HV diodes eg:UF5408 to be connected to battery negative terminal(Earth) and 0.1uf/100nf 1000 or 2000volts capacitor in parallel with bulb without full bridge rectifier for now.
I hope you guys realized by now you get nothing by applying resonance like "Ruslan" pll circuit and etc.
Getting the kapanadze coil functioning at a higher frequency (Somewhere below 90khz) if compared  to the the input frequency to yoke or toroid at nearly 50% duty was the last best achievement i have accomplished using Akula circuit(incorrect connection and produce little power out).
Circuit Safety -I work with 2 circuit breaker connected in series rated at 5Amps for 12volts and 24volts.Because sometimes one trip faster.
There is 2 set of useful video list as complied by
Bratan Ivanov
This video only watch 5 to 7 /12 -https://www.youtube.com/watch?v=K3LhvCidOkg&list=PLhG1WObRU5PztRjfcHl6AGFjbx0_cCoof&index=5
This video only watch the first 3 video -https://www.youtube.com/playlist?list=PLhG1WObRU5PyxFcRio-c1Taoky3WAoEus
Base on both video -It's the waveform and the setup eg:additional capacitors after 25..28turns which tallies with the attachement somewhat.
Without understanding Russian language at all this is where i am at related to the video and etc.
Have a good week.Bye.
Please watch my youtube videos for free without coughing out any money from your pockets. ;)
http://www.youtube.com/user/sanjev21
NickZ
   Hoppy
   I need some help.
   I am getting no output from the TL 494 circuit. It is receiving 12v through the filter, but nothing at the output through the TL circuit. The connections seem to be OK.
   Any ideas to test for the problem?
  Anyone else have a similar problem? Any suggestions are welcome
Hoppy
Quote from: NickZ on March 07, 2017, 11:44:04 AM
   Hoppy
   I need some help.
Nick,
When you say nothing at the output, have you got the scope connected and are seeing no waveform?
Assuming the chip is not damaged, Its most likely a bad connection somewhere. Post a photo of the underside of your board, together with the circuit diagram you are using.
Also, check that you have the output pins 8,9,10 & 11 connected to supply rail and ground as shown in the data sheet you posted.
verpies
I need some help.    I am getting no output from the TL 494 circuit.
Does the TL494 oscillate when connected according to the Fig.5 of the datasheet, which you've attached (with pin 4 grounded) ?
