0 Members and 204 Guests are viewing this topic.
dllabarre
Quote from: T-1000 on May 28, 2013, 01:09:52 PM
L1C1 - resonance in paralel matching same frequency of resonance on series L3C2. L3C2 resonant frequency is same as 1/4 natural resonant frequency of L2 (calculated by wire length of L2 and multiplied by 0.7 for more real proximity)
My L2 = 312cm.  Using an on-line calculator it gives 24.10 mHz... Does this look correct?
312cm * .7 = 218.4?Hz?
DonL
T-1000
Quote from: dllabarre on May 28, 2013, 01:54:34 PM
DonL
It looks correct. The http://pokusy.chytrak.cz/programy/calculat.html#WireFreq also shows similar things.
Also you need more than 20 MHz of self resonant frequency so electrons will be standing in place (as they move 10m/s in wire) and the BEMF voltage should be more than 3.7kV when you have L2 not connected anywhere. The RF detectors in few meters distance should not detect any field as well.
dllabarre
Quote from: T-1000 on May 28, 2013, 02:10:43 PM
Thank you for all your help and information.
DonL
NickZ
   T-1000:
   You are mentioning (above) that 3.7Kv are needed? So, what is the current readings needed, as well?
   What are these figures based on, are they proven data by experimentation on self running devices, or just general information.
NickZ
  MenofFather:
   I've seen those videos previously. It takes very little energy to partially light one of those red led bulbs. So, little current, that mine will light from just the capacitive link from the AC ground wiring, even with the Ac wall adapter being turned off. This although quite a surprise is still very limited lighting for any useful purpose.
As even the stray capacitive link through the AC house wiring running on the house floor and up through ones body, up on tables, etz... will do the same effect. This is not something that will light your house to any useful degree, nor is it free energy, as turning off the house breakers, will also turn off this effect.
  If the light bulb and circuit were hung on a string from the ceiling, and the rest of the circuit not touching anything, there would be no light coming from the bulb.
  I just wanted to bring this up, as to not have people thinking that it is free energy, when it's not.
To confirm this effect just turn off the house breakers, as it's due to stray AC running through most everything in ones house.
