0 Members and 301 Guests are viewing this topic.
Hoppy
Quote from: NickZ on March 21, 2017, 09:55:33 AM
   Hoppy, I have completed the driver part of the circuit and would like to test it out, to that point, before adding the snubbers. Any suggestions???
Nick,
Once you have the 15V supply rail and signal inputs connected up, you can scope the driver outputs at pins 6/7 to ground for correct waveforms. Ensure that the supply traces are kept as short as possible to the main supply bus lines and make sure that the ceramic capacitors (pins 1/4 & 5/8) are soldered directly across the pins of the driver chips. The following zeners, mosfet gate resistors and mosfets should be mounted as close as practicable to the drivers to ensure ninimum length driver to mosfet gate trace lengths.
NickZ
   Hoppy I'll test the driver output and maybe post a video of that stage of the circuit.
The 15v filtered supply lines are already connected to the drivers. Not using the bipass caps, for now as I don't have them. Nor does Stalker use them on his fet driver set up.
   Magpwr: what type of cap would you recommend? Ceremic, such as ceramic disk type? Such as the ceramic 102 cap shown on Pinoy's driver.
   Pinoy_tech:  Thanks for sharing,
   I've downloaded all of the attachments. At least the pictures I could open. Not the others.
           NickZ
Pinoy_Tech
Quote from: forest on March 20, 2017, 05:26:33 PM
Nice.What kind of pcb software ?
eaglecad with plug-ins ulp & image converter + sketchup + vray.. but under skp, all components are customized.
Pinoy_Tech
Quote from: AlienGrey on March 20, 2017, 05:42:46 PM
he has a link (a dead one)  my look ahead info says it's been hacked) good luck mate ;)
dead link? might be due to your network... that storage site is a legit and develop by trusted google...
Pinoy_Tech
Quote from: magpwr on March 21, 2017, 10:11:57 AM
hi Pinoy,
Nice Pcb but why do you choose to use Green "Mylar capacitor" as a decoupling capacitor and also for the snubber instead of sticking with "ceramic capacitor".
Youtube:sanjev21
[size=78%]
[/size]
Nope, it's not meant for that choice. that's just there as presentation to show the spacing and approx outlook of the entire pcb once assembled.
I used to render it automatically and the software picked whatsoever the assigned component intended for the designated item, I realized that
I assigned that component into a wrong one, no time to rename and rerun again.
