0 Members and 410 Guests are viewing this topic.
verpies
Quote from: AlienGrey on March 30, 2017, 07:28:06 AM
There is also another way of using push-pull energy init's own drive by winding the drive transformer in a more efficient way.
Yes, winding the transformer more efficiently minimizes its leakage inductance and the energy that snubbers must dissipate.
It is the energy stored in that leakage inductance that the snubbers must deal with.
Alternatively, the unwanted energy can be recycled back into the power supply by an auxiliary winding....without dissipating it as heat.
magpwr
Why use a MOV it's an energy waster and what you drain (waste) overheats the system and wastes your free energy (assuming you ever get any with this concoction) ;)  just use two fast diodes from the collectors a good cap and a bleed resistor back into the system somewhere like the EHT driver supply possibly.
hi,
There is specfic reason why Akula used MOV,snubber and even zeners to protect his IGBT's.
I have explained to Nickz MOV is needed to protect the diode.
MOV for my case was not implemented at first since i am using 1.2KV SIC Mosfet with 2x external 1000volts diode UF5408 for each mosfet in snubber section.
But later on i discovered components are getting damaged because of kacher.
So implementing a 820volts  ZOV(Zinc oxide varistor) for my case solved my problem for good.MOV would do as well.
I did learn it the hard way.
Nothing much to discuss since i have shown the snubber circuit in PWM circuit as attachment few weeks back.
But for my other circuit none PWM or PLL variant i am sticking with IGBT used by Akula and had no problems from the start.
Less heat generated because IGBT's are properly driven at the right voltage at around 17.xxvolts
For nearly 5 years members are still getting stuck in basic PWM circuits.Do think about it.
NickZ
   Verpies:
   I believe that my TL board is working as Stalker has his operating, and possibly similar to how apecore's T494L set up works, also.  Even though it may not be working as you would like to see it doing. It does produce the same or similar scope shots, as what Stalkers circuit produces, as can be seen on his last very comprehensive and well explained video.
   I may make another TL494 board, (without the voltage regulators and filters), and just test it on a 12v battery. That way I don't have to get the first board all messed up with more changes.
   The new board can be made exclusively for testing your "proper" connection method. As I have 4 more TL494 chips, as well as most other needed components.
  However, as I explained previously the reason that your suggestions did not work for me, was due to the connection to pin #3.
   As you can see on Stalker's set up, his toggle switch connected (when closed) between the #3 pins, and the three 13,14, and 15 pins will kill the output from the pin #9 and #10. That is exactly what it was doing on my set up, although only one of the two outputs was not working. And that was why I went back to the Stalker connection method. But, without the #3 pin connected up to anything, and just left open, with no toggle switch, as it's not needed, at all.
   On Pinoy's schematic, the #3 pin is left open, as well as on the TopRuslan schematic. There must be a reason that they are doing it this way.
    In any case, I'm not afraid of getting "bitten", and expect to continue testing the circuit, until it WORKS, as expected.
    Thanks for your help. I do appreciated it.
    PS. Although I have been busy with other things, I expect to finish with the snubbers, and will be able to test the workings of the circuit connected to the rest of the device.  I will show in videos, step by step what I've done, and the results of those tests, for myself, and for anyone that may be interested.
        NickZ
AlienGrey
Quote from: magpwr on March 30, 2017, 09:24:05 AM
hi,
Magpower Hi, that's an interesting comment, I did look back at your circuit but am a little confused on how you drive the IGBT's at 17 volts  I was wondering if you might have ment 15 volts via 7815 perhaps and seeing other circuit with IGBT's is a new one on me so to spoeak although I have used them in a couple of driver circuits, I have experimented with myself, regarding the Katcher what type of device are you using there, as Drain Sauce resistance is really important to keep to a minimum there if EHT quality is important ?
Regards AG
PolaczekCebulaczek
Ok, just a quick question about mixing AC signals of LF and HF.
In the configuration below, how do I tune Tesla coil frequency to get maximum power in (third) output coil?? to take energy from 60 HZ AC source.
