0 Members and 264 Guests are viewing this topic.
Quote from: PolaczekCebulaczek on March 30, 2017, 06:40:31 PM
Ok, just a quick question about mixing AC signals of LF and HF.
In the configuration below, how do I tune Tesla coil frequency to get maximum power in (third) output coil?? to take energy from 60 HZ AC source.
Try tuning the output coil itself, by putting a capacitor in parallel with the coil and/or varying the number of turns in the coil. You could also try installing a ferrite core that can be adjusted in and out to vary the inductance of the coil.
Hoppy
Quote from: NickZ on March 30, 2017, 11:45:03 AM
   Verpies:
   I believe that my TL board is working as Stalker has his operating, and possibly similar to how apecore's T494L set up works, also.  Even though it may not be working as you would like to see it doing. It does produce the same or similar scope shots, as what Stalkers circuit produces, as can be seen on his last very comprehensive and well explained video.
        NickZ
Nick,
Its important to replicate the circuit as accurately as possible, just in case Stalker has achieved something special. However, its quite likely that you will do some TL494 config changes in the future, as suggested by Verpies, so order up a few IC sockets ready for the changes.
PolaczekCebulaczek
Quote from: TinselKoala on March 31, 2017, 12:17:13 AM
Yess, but this 60hz source would have effect on TC output coil?, this is possible right? :D
magpwr
Quote from: AlienGrey on March 30, 2017, 11:56:16 AM
Magpower Hi, that's an interesting comment, I did look back at your circuit but am a little confused on how you drive the IGBT's at 17 volts  I was wondering if you might have ment 15 volts via 7815 perhaps and seeing other circuit with IGBT's is a new one on me so to spoeak although I have used them in a couple of driver circuits, I have experimented with myself, regarding the Katcher what type of device are you using there, as Drain Sauce resistance is really important to keep to a minimum there if EHT quality is important ?
Regards AG
hi Aliengrey,
It's around 17.80volts as obtained from SMD version of 18volts  requlator which is powered by XL6009 Buck/Boost circuit set at 20volts which cost mere $1.99usd ea .
I am using dual driver in one package IX4427 to save space.
20volts is for powering inverted mosfet driver IXDI614 for the kacher part of the circuit which is powering a SIC Mosfet.
The most easy circuit to tune the kacher is the sergey version as attached no more ferrite rod insertion.Fine tuning from 1Mhz to 2Mhz.
The sergey circuit used in his setup base on my study is actually orginated from Oleg design as attached.
But there is enhancement made at Oleg circuit across R8 there is a SK diode 1N5818...1N5819.Not shown in attachment.
This one diode enables the high frequency interrrupter pulse to appear in the middle of the trailing edge from either A or B channel or both from before the mosfet driver.Very creative design indeed.
74HC132 x 2 I/C is optimized to the max.
The most important component is the C5 which Mica capacitor 470pf is used for extreme frequency stability.The support resistor R7 and R8 can be changed to one pot 500 ohms in the final design.
R10 is not needed and C6 1nf is changed to 4.7nf.
Please try assemble top half of circuit onto a protoboard with 1x74HC132 and provide 10khz.Please use 2 channel and adjust pot such that a signal will appear in between trailing edge for testing.
Assemble and observe the result,tweak component where applicable should be not asking me any question about this circuit function anymore.
What the above circuit does is upon combining with parametric osillator (set at sub-harmonics of L/C resonance using LM393 for the front end) then at the right position of interrupter pulse and frequency.
Say the parametic osillator is running at around 10khz which is a sub-harmonics of the L/C resonance at 3 turns combine with the sergey circuit tuned right will cause the kapanadze output to produce a nice sine-wave at somewhere just below 90khz at the output.
So think about it picture this 10khz(A sub-harmonics) oscillation produce a nearly 90khz "sine-wave" at the output with kacher
(sergey circuit running at under voltage 12volts instead of 200volts dc).The higher the kacher provided voltage the higher chance for output to create a high frequency sine-wave
Is this device considered a particle/electron accelerator without use of cavitation???
Good Luck to the rest since i can't show the other aspect of the circuit.
Quote from: Hoppy on March 31, 2017, 05:54:56 AM
Nick,
Yes, and also put some desoldering braid and a flux pen on the list. And do try to get a few genuine Texas Instruments manufactured TL494s, there are a lot of fakes and poor performers out there.
