0 Members and 98 Guests are viewing this topic.
NickZ
  What I'm trying to achieve, is to replicate the effect shown by Akula, 1000 WATT output to bulbs, using just 12v (and 10 watts?), or so, input source to kick start it up. Maybe much more than just 10 watts is needed, like maybe a 200 to 400 watts shock blast is used, to kick start it.
  As Tiger has seen the device, maybe he knows more about it. Than having no trusted diagram, to go on.
   I suspect that since the Akula's device is getting 220v Dc from the inverter/rectifier, that although I see the brown filter cap on the driver, that will drop that input, it may still be getting something like 50 DC volts to the driver circuit, and who know hows how much is actually getting to the yoke 12 and 12 turn primary coil/3 turn secondary coil.  What would your guess be?   That is, what voltage/current level would you think is needed for the yoke primary/secondary coil, to output to the yoke circuit turning AC capacitor, then to the resonator coil, mounted on top of the big air coil???
  I don't really see any aluminum sheeting inside his air coil, and I suspect that the choke has about 40 turns of insulated wire on it, and possibly a small tuning cap of unknown value on the bottom of the choke coil.  That may be all there is to the choke coil, possibly.  If someone knows more about it, please let us know.  Any additional info is welcome.
MenofFather
Quote from: NickZ on May 28, 2013, 04:48:35 PM
  MenofFather:
   I've seen those videos previously. It takes very little energy to partially light one of those red led bulbs. So, little current, that mine will light from just the capacitive link from the AC ground wiring, even with the Ac wall adapter being turned off. This although quite a surprise is still very limited lighting for any useful purpose.
As even the stray capacitive link through the AC house wiring running on the house floor and up through ones body, up on tables, etz... will do the same effect. This is not something that will light your house to any useful degree, nor is it free energy, as turning off the house breakers, will also turn off this effect.
  If the light bulb and circuit were hung on a string from the ceiling, and the rest of the circuit not touching anything, there would be no light coming from the bulb.
  I just wanted to bring this up, as to not have people thinking that it is free energy, when it's not.
To confirm this effect just turn off the house breakers, as it's due to stray AC running through most everything in ones house.
In this video no graund wires or antens. And it work many hus, about ten hours he say in video, that in morning turn of and work... It not possible run from capasitor!
", as turning off the house breakers, will also turn off this effect." He not say that.
" To confirm this effect just turn off the house breakers, as it's due to stray AC running through most everything in ones house." Is not mine divice. If you want get more energy, need better make divice and bigger.
MenofFather
"what is, what voltage/current level would you think is needed for the yoke primary/secondary coil, to output to the yoke circuit turning AC capacitor, then to the resonator coil, mounted on top of the big air coil???"
I say, in yoke gose from invertor, In yoke primary is 220 volts gets. Red wire in yoke maybe not conected, or not important conections.  On 3 windings in yoke is about 40 volts. Capasitor is about 5 mkF. On primary red air coil voltage can be from 40 volts to about 100 volts and on it sine. In primary youke curent is about 1-3 amps. On 3 turs is about 8-10 amps. Son on red primary on air core is 6-10 amps. Capasitor can increase voltage and decrease amps. Better replicate Dally divece, it not have any big secrets. I can help replicate or divece who show with 3 watts LED lamp. Then you not spend many manny if you can not succes replicate and for you it not works.
itsu
I pulsed my two parallelled MOSFETs with a much higher gate frequency (5.6Khz), causing the voltage on the capacitor to rise 5 times higher as in the no pulse situation (222V versus 47V).
I wonder what will happen if i also could pulse the lower half of the sine wave.
Video here: http://www.youtube.com/watch?v=zGieOdkZIN4&feature=youtu.be
Regards Itsu
slapper
thanks itsu. that is an excellent coil shorting demonstration.
i'm seeing the same flattening of the spikes as you are.
the spec's on the mosfet, Vdg, is inline with the voltage flattening.
i think i'm going to introduce a low turn primary and drive this primary to kick the voltage up.
thanks again.
take care.
nap
we are not alone :)
