0 Members and 226 Guests are viewing this topic.
NickZ
   MenofFather:
   Quote:
   In this video no graund wires or antens. And it work many hus, about ten hours he say in video, that in morning turn of and work... It not possible run from capasitor!
", as turning off the house breakers, will also turn off this effect." He not say that.
" To confirm this effect just turn off the house breakers, as it's due to stray AC running through most everything in ones house." Is not mine divice. If you want get more energy, need better make divice and bigger.        End quote:
  I have made a similar device, and can tell you that it is running on the house wiring stray AC capacitive link.  If the house breakers are turned off the weak red AC bulb will also be turned off. NO antenna, or ground needed.
  I know that it's not your device, but I'm just saying that it is not a free energy device, as it depends on the grid and house wiring stray capacitance to function. That is what I think, as the red bulb is weak and not anywhere near the normal mains output level.  You can try it yourself and see, it does not need an antenna or ground, but it does need to be where is can pick up the AC grid stray capacitance. It will not work if suspended on a string without touching anything.  That is my opinion, and the best test is turning off the house breakers, to see how the device dies.  IF this is not the case, then there is another cause, but first that is what I've already proven in my devices. The test is very easy to do, and no he is not saying that, nor testing what I've mentioned either. That device is not new, nor did he improve on it, after a couple of years. Or did he? And why not?
If you find out something different, please let us know.
NickZ
  T-1000:
   I don't understand the logic of showing that last diagram. The Russian (fat guy) in the video is showing a Kacher or Tesla type coils, using wireless electrical energy to light a single bulb a few feet away, not brightly. What is the point, and how does that have anything to do with the self runners that use no input source to run?
T-1000
Quote from: NickZ on May 29, 2013, 12:29:30 PM
  T-1000:
There is separate test case showing wireless power transfer and it is cold electricity going out of "hot" end of Tesla coil. This relates to BEMF you get in release of switch as well. The circuit diagram shows how it is possible to convert it back to conventional "hot" electricity.
Also when you have high frequency BEMF you cannot take power directly out of circuit. The circuit which Dynatron shown on video is one of approaches how to take BEMF input then condense on series of capacitors then attach 50Hz step down inverter with resonant LC circuit on primary for this frequency so you get strong induction and power transfer out of transformer. This approach can be seen even in http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/124146/image// (if you try to replicate remove BEMF shorting diode on primary of top transformer, that was done with intention to fail people who do not know about BEMF conversion) on "choke" which is actually is autotransformer with first half part of it doing same function as I just described.
NickZ
Quote from: MenofFather on May 29, 2013, 03:00:41 AM
"what is, what voltage/current level would you think is needed for the yoke primary/secondary coil, to output to the yoke circuit turning AC capacitor, then to the resonator coil, mounted on top of the big air coil???"
I say, in yoke gose from invertor, In yoke primary is 220 volts gets. Red wire in yoke maybe not conected, or not important conections.  On 3 windings in yoke is about 40 volts. Capasitor is about 5 mkF. On primary red air coil voltage can be from 40 volts to about 100 volts and on it sine. In primary youke curent is about 1-3 amps. On 3 turs is about 8-10 amps. Son on red primary on air core is 6-10 amps. Capasitor can increase voltage and decrease amps. Better replicate Dally divece, it not have any big secrets. I can help replicate or divece who show with 3 watts LED lamp. Then you not spend many manny if you can not succes replicate and for you it not works.
  I'm trying to understand what you mentioned in the quote above.
That the yoke is getting it's 220v power from the inverter (not through the driver circuit?).
And that the 12 and 12 turns coil primary current of 1 to 3 amps, and 220v. Red yoke wire not connected to anything, or is not an important connection. And that the output from the 3 turn coil is about 40 volts, and 8 to 10 amps, going to 5 uF 220v capacitor, then to the red resonator air coil that has about 40 to 100 volts on it, and about 6 to 10 amps. The capacitor can increase the voltage by decreasing the current.  Is this what you mean, so far, or not?  This is the circuit that I am working on now, not other circuits at this time.
  Daly's device was not able to be replicated by Itsu, or any others that I know of.  Maybe it has no secrets, but it was not able to be replicated by any others, yet.
Hoppy
Quote from: T-1000 on May 29, 2013, 01:07:13 PM
Please stop calling it BEMF. The link you give is not a motor circuit! its also not a self-runner. Nick is looking for a self-runner. Do you have a genuine self-running schematic that you are prepared to post? The various Dally circuits posted are also not self-runners.
