0 Members and 119 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on April 16, 2017, 09:50:53 AM
   TK:
   It's not the scope, or the channel trigger settings at fault. I have tried to swap the probes, etz... same thing.
The fets get hot very quickly. Apecore's fets don't get hot at all, using a similar TL circuit.
   Last night I found one more still use able IRFP260N mosfet, so now I have two fets working again, and I can show the scope shots that you requested, later today.  But, in any case there is practically no output at the bulb, or bulbs.  Similar to Itsu's last video, and results.
   Yesterday I worked 12 hours, at my normal job, and today it's going to be similar. So, I stayed up until 1am last night working on my circuits.
This has not been an easy fix, so far.  But, I'll get it going right. At least the duty cycle and frequency are working, to some degree, enough to continue testing the circuit.
I((F)FDP260s are only 200 volt, i think mine are 600volt but you can get 1200volt Fast devices, I bet your getting a good overshoot with that devices and then sinking it to earth, wouldn't some faster devices be better and rewinding the torrid to put most of it back into the system ? This is my waveform notice the waveform. Hope it helps I only have 1 high voltage probe so can't display both outputs at the same time.
x_name41
hello to all, there are important message from Tariel, he says so: in the device is amplified only a current component, furthermore pulsed and necessarily need have a grounding... I attach the original message
stivep
Quote from: x_name41 on April 18, 2017, 09:57:26 AM
Till yesterday I was for the whole week at Tariel place..... Schematic "Sapoga"
Tariel and Timur  with laugh  responded.
This "thesis" to the point..... from that what is  allowed to be said.
1)Ground wire  in schematic must have.
2)Spark gap    must have.
3)To start process needed to have phase and zero( ground) The one or the other:(either) from generator  or from  electrical  outlet.
At output  two phase ,voltage should be the same at input as in output. ( ground wire must have)
there is amplification of current component in formed impulse (  in impulse by itself)- (that is what he said  current amplifier) and this is inconvenient ,
when dissipated there is need to "isolate it - separate" , expensive converters, or do it different by rewinding synchronous motors so that one would be driving hydraulics  or flywheel.
I have no rights to give you more information, but I hope a lot of  falsification-schematics will be rejected.
I wish you luck
Free energy Exists.
End of translation
From Wesley
To some who criticize me
I do not care if you like my comments or not . I believe that in my long comments I include essential  details  If you do not  like it I will simply stop to write.
Hydraulic concept was the one  Tariel was talking me to finance . And I have no problem to  find people with money.
I opposed to it as well as that particular  wealthy friend of mine did.
We both are for noncommercial activity.
But there is significant connection  between synchronous motors and Tariel concept.
Presence  of such motors we have seen in most of Tariel presentation.
But new and essential element in this present  comment starting this post is flywheel.
Yesterday I have had (incidentally)  a discussion about  forms of temporary  stored energy with my friend  in science John
So in means  of  temporary energy storage  we have:
1. Flyback transformer from  CRT TV. Temporary energy storage is made by means of gap in ferrite core.
a. the same story  happened in Lithuania experiment when the only way that Aidas device start to work was when me and Arunas we requested from Aidas to place paper divider  between two half 's of ferrite core from Rubin CRT
b. we might also see SR implementing divider/ spacer in his ferrite assembly.
2. Flywheel  Mechanical flywheel  was used for  long time  as energy storage when  rotational mechanical moment was by all means serving well to the point of need for that energy to be converted back to electrical energy.
And that is what Tariel is talking about   mentioning  either/ or  - flywheel/ synchronous motor
3. Hydroelectric energy storage
think of it as  another means of temporary energy storage
http://energystorage.org/energy-storage/technologies/pumped-hydroelectric-storage
Tariel third device was the one that used hydroelectric mechanism.
And now guys try to find in this puzzle some sense knowing that Tariel started from electrostatic device where capacitive reactance also serves as temporary  energy storage
than he transition form spark interrupter ( complaining  at instability of electrodes) to electronic impulse interrupter ( gas stove HV impulse train generator)
than he  transition himself to hydroelectric device
but in the meantime he presented in Germany  Flywheel  motor coupled  with electric motor by  belt.
Every  of his  experiments have had some sort of  energy storage e.g bank of capacitors, motor with nothing connected  to it or 3 motors( for three phases)
Every of his experiment have had  HV
Every of his experiments have had ground wire
https://youtu.be/7Ldus3AQSpE?t=928 - this was Tariel Hydro electric device
Wesley
http://www.controleng.com/single-article/monitoring-induction-motors-for-energy-savings/5bfaa5385d8bab73100e37d54caec817.html
http://www.free-energy-info.com/P25.pdf
x_name41
x_name41
and some my small experiments with schematics, in brief when turning on the "kacher", their shining of the lamp is amplified and in adding grounding is amplified further
https://www.youtube.com/watch?v=BpjFCVj_S8g
https://www.youtube.com/watch?v=jIc1LGwgrIE
