0 Members and 164 Guests are viewing this topic.
Void
@Nickz: Ok on all that. Yes, still sounds like a mystery... :)
AlienGrey
Quote from: Void on May 15, 2017, 04:52:43 PM
Hi all. Long time no talk. Have been really busy and haven't checked in here in a long while.
It's nice to see many people still hacking away at this puzzle.  :)
I read back a bit in this thread and it seems stivep visited Kapanadze again recently? If so, that sounds interesting...
Read something here from stivep about the Kapanadze process supposedly working via current amplification, and impulses
such as a sparkgap and earth ground being required, plus capacitors for energy storage  Hmm... Sounds like not much more info than
was being thrown around in the last few years? Narrowing it down like that that maybe helps keep things simpler however...
Anything new from Akula and Ruslan these days?
I saw that Ruslan has a newer video about 'fart pants energy' or something like that.  Sounds promising... ;D
P.S. Any indication the length of the earth ground wire may be critical in Kapanadze's setup,
or does it appear that any length of earth ground wire works in Kapanadze's setup?
Knowing if earth ground wire length is supposed to be important or not in Kapanadze's devices could help narrow things further...
All the best...
Ever thought it could be a harmonic of the grenade tuned frequency 'wave' or fraction of it ?
Void
Quote from: AlienGrey on May 15, 2017, 06:49:31 PM
Yes, of course, and such an idea has been discussed here in the past...
I was kind of more wondering if Kapanadze had made any comments about that to stivep or in his
previous videos, or if anyone has noticed whether the length of the earth ground wire in Kapandaze's demos
seems to be just fairly random or not...
Hoppy
Quote from: NickZ on May 15, 2017, 06:02:54 PM
   Hoppy:
   Can you explain a bit as to just what the diode is supposed to do. And also, what type of diode do you recommend?
Nick,
The regulators are rated typically at 1 or 1.5A, so a 1A 1N4000 or similar diode in series with the supply will simply provide reverse polarity protection in the event that you accidentally reverse the supply to the regulators.
If you destroyed the regulators just by reversing the yokes primary connections, then its understandable as this would have spiked the regulators and caps if done whilst the yoke was powered-up. I assume that you are supplying the yoke primary direct from your source power supply and not from a voltage regulator?
The learning curve involves a fair bit of smoking.  ;)
NickZ
   Hoppy:
   Ok, thanks.
   I'll get the regulators and filters replaced soon.  I already did replace them a couple of days ago, but with ones that I had burnt out previously. As I forgot to check them before doing so, as they looked new, but weren't. Me bad... it was late at night, and with low light levels. Oh well.
But there was no smoke, the filter caps just exploded in my face.
   Anyways, I was able to get some interaction and sync from the Kacher to the induction circuit, before this happened. Which was the first time I've seen that with the TL board.  That's the good news.
