0 Members and 402 Guests are viewing this topic.
AlienGrey
Hmm i did some software for 16f84 20mhz one it had no trouble doing the waveforms but once HV pulses EMF were reached it would go mad ;) EMP ;) they can't cope with it, perhaps EMP is the key don't know/
NickZ
   20MHz is way to high for either the Kacher or the induction circuits.
   Induction circuit should run at something like 15- 27Khz and the Kacher 1-2MHz.
   Don't know you mean by 16f84 20MHz.
AlienGrey
Quote from: NickZ on May 30, 2017, 07:40:47 PM
The 16f84 is an old microchip, microcontroller look it up it divides the clock by 4 so you have 5 usec blocks in time to play with, you don't have to use 20 Mhz clock you can use any freq you want it just means 20mhz is the maximum clock speed its totally programmable and dead cheap. I think Microchip are now into the satanic darker side of things now like chipping people with the bloody things oil barons and their cronies so I'm told.
T-1000
Hi all,
In addition to the input of AlienGrey and zalmoxis, there is no difference what you feed into low frequency part.
The heart of device is the Tesla coil which is making same conditions as pre-lightning in the rain.
I was also told several times by akula and others, the Tesla Radiant receiver (patent US685957 -  https://teslauniverse.com/nikola-tesla/patents/us-patent-685958-method-utilizing-radiant-energy ) is a simple way to detect right conditions when it is near top load of the Tesla coil and the potential on "live" wire is always positive in relation to the ground. No matter what polarity is on the Tesla coil, it never changes on the right frequency with sharp dischage and the right voltage. I was also told by akula, that potential stays for quite long time after Tesla coil is switched off..
It is the electricity harvested from the air charges on those devices!
So here are clues what to look for before going down another rabbit hole with the LC resonances and more complex circuitry.
Cheers!
NickZ
   T-1000 and All.
   If it's so simple to produce the proper effects, and you mention it doesn't really matter if an arduino or some other controller circuit is used for the induction circuits, then why have you not been able to obtain any positive results, and produce a self runner? After all these years...
   Also, if commercially ready made controller circuits can be used just as well as the fairly complex ones that Akula and Ruslan (Oleg) and others are having to create, then why are they not using them, instead of spending time, so much time to invent their own?
   At one time it was thought that the Tesla coil could not be frequency controlled other than by adding or removing turns on the secondary coil, etz.
Now we see that that is not the case. Yet, every single Tesla coil of all the self runners devices are running at different frequencies, and use different sized secondary coil.
Also, IF potential is still left on the Tesla coil once the input power is switched off, then why is it not showing up on the scope, or anywhere else?
   The only way that I can accept your thoughts and statements, is by proving them to be right, by showing a self runner, or at least showing what you mean.
   As I mentioned, if each and every one of you guys want to try to invent your own way of achieving the desired result, by all means, go at it.
But, you'll be own your own...
    Also, keep in mind that even Kapanadze, who started this whole thing, was not the inventor of his circuits. Which Akula, Ruslan, and every one else showing self running devices have based their working versions on.
   Theories are fine, so long as they are backed by positive proof.  Otherwise it's just more and more unsubstantiated talk, with no one building anything to show for it.
   BTW: Tesla never mentioned that energy is coming from the air, nor the ground. He said is was drawn from the "surrounding ambient", in reference to the Aether, and not the physical properties of air nor the Earth.  Aether is ever present everywhere. Although we have no way to detect it, as yet.
   I will make another video of my device, soon. It seems to be working better now.
