0 Members and 292 Guests are viewing this topic.
T-1000
Quote from: Dog-One on June 01, 2017, 10:14:59 PM
Not new, but interesting yes.  Start with this, look deep and comprehend what
each piece of it does.  What you'll discover is the modus operandi is very similar
to Ruslan's device, without the ground wire.  The inventor of this device you will
recognize.  He didn't copy it though, he envisioned it, piece by piece, function by
function.  It's the approach we all should take--understanding what we are doing
and why instead of copying from someone else.
Exactly, the technical solution may appear totally different from what everyone is used to see. But using same pcinciple of operation.
Still makes me wonder a bit, how Nelson fitted all pieces into small space if modus operandi is around electricity from air...
zalmoxis
my first public video  ;D https://yadi.sk/i/WKGwoV_s3Jkm8t
At this moment I'm stuck, i don't know what else to test/tune .. i've tried different yokes ferrite rings , with middle tap, and tesla byfilar winding .. i can't get the amplification effect. I use a 15m 16mm^2 ground wire.
zalmoxis
I want to share again with you a video from Sergey: https://yadi.sk/i/jqjH477n3JknSj
He is using a byfilar winding as a primary on his ferrite ring.
On his scope screen we can see that his push-pull duty cycle is very close to 45-49%
His second scope probe is connected after the series resonance capacitor(s)
We can see that his cap probe sinewave falls perfectly at the begining of the driver Square, and the yellow "ringing/spike" is before the begining of the red square. Probably there is the end of the second driver Square.
When he connects the load, the amplitude drops a bit then returns to normal as if there is no load and some ringing appears on the top of the red square and it also appears on the yellow sinewave.
On this specific board he uses some 3uF capacitor  in series from tesla PSU to tesla primary coil.
The only aluminium element looks to be just the antenna.
From the video analysis the system is powered 15.4V  and 5.17Amps (without load) he does not show PSU measurements with the load connected.
Also we can see that layer 5 and layer 6 of the grenate is not 1/4 of the total length of the coil .. of maybe his 3rd layer of the inductor passes over the Layer 4 of the grenate. also from that video i can see that he is not using all the bank of capacitors connected on the grenate but only one small green cap.
No matter what kind of pushpull circuit we are using or if we use tesla or kascher this scope image is good for us.
NickZ
    Zalmoxis:
    His frequency is running at around 8.484KHz on his push pull, as it's running in the audible ranges, and can be detected on a  spectrum analyzer.
   Can this frequency I've given be verified or compared by watching the videos of his scope shots?
GeoFusion
Hi  all :),
As what T-1000 has posted
the electricity harvested from the air charges is what makes these devices work.
The ions and positrons are abundant around us, on earth and outer space,
our sun and the center sun of our planet produces the charges continuously waiting
to be used in many forms.
Tesla coil is indeed the Heart of most of these devices / Devices which operate on charge / discharge of Hv.
Which Attract and activate these ;).
Lighting is the clear example of it, all the charges that is and create that condition within a device.
Imagine the continuous lighting strike within and siphoning energy from it.
here are 2 videos where shows how important the Kacher / Tesla coil really is.
You will see high voltage being generated at output of the grenade and which is then charged and discharged rapidly
from the caps and which creates the output we all want.
It will give you a hint also what is happening on Vasmus's system ;)
1
https://www.youtube.com/watch?v=LGRS6SVmcoo
2
https://www.youtube.com/watch?v=el1SkfaHmsI
Cheerz to all.
