0 Members and 273 Guests are viewing this topic.
NickZ
   Hoppy:
   And your scepticisms have been repeated many times as well. Perhaps you can suggest a way that these things CAN be proven. Or do you not even trust witnesses going and seeing the devices and testing them, either?
What can you suggest? Are you willing to go and see for yourself? Would that do, or not.
   There is no use repeating things for so many posts and no one actually doing anything about it. Boring...
   The big picture is that we get nowhere by continuing to repeat these same things.
   How about a little more than just that. That's all I'm suggesting. We've already lost most of our old timers, by no results and just more and more talk. Even apecore is hardly posting now. And he is really working at this.
  Stivep has at least gone to see the main man, and is now a witness to the true workings of the kapanadze device, as was Tiger to the Akula's device. And I do have to trust some one, other than myself.  Does any one trust me...No?
Believe it or not, that's your choice. Or, perhaps we need more theories, instead.
zalmoxis
Some videos made today  https://yadi.sk/d/X2QGdb_43Jmy4L
Hope that will be useful for somebody  8)
NickZ
   Zalmoxis:
   Thanks for the pictures and the video links.
   Can you tell us if this device is supposed to be self running, or not?
   Please check your previous post, I've made a new comment there.
zalmoxis
Quote from: NickZ on June 02, 2017, 09:58:11 AM
    Zalmoxis:
    His frequency is running at around 8.484KHz on his push pull, as it's running in the audible ranges, and can be detected on a  spectrum analyzer.
   Can this frequency I've given be verified or compared by watching the videos of his scope shots?
He has multiple videos using different frequencies. On the videos with the pink coil i remember he said he is using some 8Khz .. and 16Khz .
Dont analyze the pushpull frequency by the yoke audio frequency. There are multiple factors like audio compression, and the mechanical vibration sound could be different than the actual frequency used.
From all his videos he is using 8khz 16Khz .. but on some diagrams like his latest one you can see 3,34Mhz / 23.5Khz.
With 19meter inductor and 340nF it "resonates" at 16,7-16,9 KHz, tested!
WIth 340nF and 9.5meter is around 23-25Khz.
zalmoxis
Quote from: NickZ on June 02, 2017, 06:31:18 PM
   Zalmoxis:
If you put 100Watt in and you get out 110Watt then it can be a self runner!
From all my tests since november i was not able to get more out than in.
What type thickness / length of ground wire are you using, and what kind of earthing ?
The only video it was a self runner was with the ground wire connected and some 8-10Bulbs lit. The video was shot in his lab... not in the field like Ruslan.
Also he has another video using a kasher instead of tesla and as a load has a high power heater element (washing machine type). From his scope images you can see when he shorts the gate of transistor with ground also the output voltage with load attached DROPS!
All this kind of devices are similar with the grenate/inductor and some tesla/kasher.
Why this effect happens i don't know. When this effect happens .. we have to find it out!
There is a russian guy Sergey Stalker, i have talked with him, he said he was able to self run and 200watt load max, he did not used any hidden aluminium coil. I did not see the device .. just his words.
For 19 meter inductor and 8Khz do you have any clue on the series capacitor value to be used? 500-600nF
I can bet that this is not rocket science ... is something very simple .. but that key is unknown for us.
Does anyone of you have access to a spectrum analyzer to test a grenate of 37.5 or 38m the "self resonance" ?
Probably i will have access next week to some University lab to test it .. (i'm too old for school  ;D )
One ideea is like .. if it resonates at 8Mhz .. we should hit with tesla at 2Mhz (1/4) and with 20Khz with push pull + caps .. just an ideea
I tried to "measure" the grenate. Device OFF, shorted grenate and put a small ferrite ring with 300uH inductance and connected it to the scope.
On the second scope image i have connected the earthing wire (15m  16mm^2) and ..
Also all these peaks repeated somewhere around 140-300Khz interval i don't remind it precisely!!
I have did the same test in the city using the heating pipes as a ground and some pattern appeared on the scope every 72-74Khz .. so that "frequency" changed with an "official" Earthing. I can't make any link between these numbers ..
